lsa blower swap?
Hopefully it's not an issue with that routing, but I like having the extremely validated and over-engineered stock setup for piece of mind.
"Let's make a 580 HP car, but we'll make it idle smooth, get decent economy, have AC AND be quiet."
LS2 block .05 over
mahle -5 pistons
Eagle H beam rods
WCCH stage 2 LSA heads
CHE rockers
Custom comp cam
Hooker exhaust manifolds
2.5 mandrel stainless exhaust side dumped
Oem blower pulleys (for now)
ZL1 intercooler pump
Alan Grove low mount AC
Aeromotive a1000 pump (in tank)
Made 550/520 on a "heartbreaker" mainline dyno
So far she runs great.
Attachment 518075
Attachment 518074
Attachment 518073
LS2 block .05 over
mahle -5 pistons
Eagle H beam rods
CHE rockers
Custom comp cam
There is a '13 ctsv supercharger locally for $800. But no other parts.
Thank you all!
Thanks. That's quite a fleet of 2nd gens haha. I'd love to do a 80ish or a 3rd gen, but after seeing what I spent on this I'd just lose to much money haha. Hoping the 70-73's start holding value closer to first gens... Not that I plan to sell any time soon.
I have the GMPP LSA harness/PCM and just had it dyno tuned as I have changed the cam/injectors etc. Made 552 RWHP on 5 lb boost. The original tuner I was going to use insisted I run stock pulleys because of 10.5 compression. He ended up bailing so many times on tune appointments I went w someone else, who like everyone said I should have pullied down!
Thanks! No build thread unfortunately.
Thank you all!
I chose to just pull the VVT and put in a regular cam so I could use a LSA FEAD. The VVT + supercharger does make for some crazy torque potential, but it's a little trickier to tune.
#5 12622452 Top Left Tensioner on SuperCharger GM Parts Direct $123.38
#7 11588753 Bolt for tensioner $2.44
#10 12606031 Idler Pulley $69.72
#11 12606032 Idler Pulley $57.95
#14 12606501 Bracket $57.10
#15 12606500 Bracket $25.01
I realize I missed a few bolts and little things, but GM uses the bolts for so many different things, I couldn't be sure which bolts I needed when using part #'s in GMPD.
Can anyone here who has this setup, please measure what size the idler pulleys are, and post up in this thread? I don't see any reason to buy a $70 Idler pulley, when there are tons of them out there cheaper, just need to know size.
Attachment 518198
Nice piece that fit well in the license plate area between the bumper teeth. Works well with 3/4" lines and ZL1 pump. I opened up the supercharger lid to -12 too. I have a little experience in the CTS-V world so I know what works to help keep IAT2 Temps down.
You also want #4. The LSA main accessory tensioner is slightly different to clear the idler bracket. You prob wont find any cheaper alternatives to the idlers as they're extra wide and dual bearing to prevent wobbling under load. Some diesel parts may do the job but they're just as expensive
Bolts are your call. Fastenal or similar will cost about the same but wont be flange head 15mm like every other M10 bolt on the engine. Waste too much time scrounging a JY for similar bolts. The M8 bolts that attach the idler bracket to WP are easy though. The long through bolts can be had from an old headbolt kit. The M8 bolts are not TTY and come with new bolts kits anyways. The lone short M8 is the same as the F/R/valley cover bolts
What are your overall impressions of the l92 heads and lsa blower combination?
My plan is to start with the lsa FEAD, lsa cam, and lsa pcm to make life easier in the long run. All for a ls2 with the 4.8 crank and rods, making 328ci, l92 heads, and the lsa blower. Hopefully going into my s10 after I swap it to the astro/bravada awd.
