lsa blower swap?
#123
rpturbo
You also want #4. The LSA main accessory tensioner is slightly different to clear the idler bracket. You prob wont find any cheaper alternatives to the idlers as they're extra wide and dual bearing to prevent wobbling under load. Some diesel parts may do the job but they're just as expensive
Bolts are your call. Fastenal or similar will cost about the same but wont be flange head 15mm like every other M10 bolt on the engine. Waste too much time scrounging a JY for similar bolts. The M8 bolts that attach the idler bracket to WP are easy though. The long through bolts can be had from an old headbolt kit. The M8 bolts are not TTY and come with new bolts kits anyways. The lone short M8 is the same as the F/R/valley cover bolts
Pocket,
Thanks for the info. I completely forgot about these being 8 rib, damnit. GM is pretty reasonable with their bolts imo, at least most of them.
#124
Here is also Chevrolet's installation documentation for the LSA drive package with part numbers:
http://www.chevrolet.com/content/dam...m-19303242.pdf
CTS-V PS pumps are the same for all versions. Only the tank changed for LSA V2's to clear the TB better. Surprisingly the V1 white tank still clears the TB barely
#125
#126
Very nice cars posted with the completed swaps. Good execution, gentlemen.
What are your overall impressions of the l92 heads and lsa blower combination?
My plan is to start with the lsa FEAD, lsa cam, and lsa pcm to make life easier in the long run. All for a ls2 with the 4.8 crank and rods, making 328ci, l92 heads, and the lsa blower. Hopefully going into my s10 after I swap it to the astro/bravada awd.
#127
We did, indeed, speak on LatG, I apologize for not recognizing who you are. That really sucks about your original tuner's customer service. But I'm glad you found someone to tune it so you can enjoy it. Increasing boost via pulleys is easy enough to do down the road, you can at least drive what you have and work out all the little bugs before stepping up to kill mode.
#128
Really though without mini tubs and big rubber any more torque is just wasted, as it sits it's very fast and drives awesome. It ended up being tuned by Dr Phill who is really good local here in Detroit, highly recommended on here and from some of my friends/builder.
#129
Can anyone confirm the length of injectors that fit? I am trying to find out if they are the longer or shorter style. I want to buy some aftermarket SD. I think I am going to get 80# injectors. I figure they will be a bit big for for a stock setup, but I plan on a cam, ported heads and blower if I go this route, otherwise, I will have a TC78 Turbonetics and 12#'s.
#130
I'm chiming in at the tail end of some of this, I have not read all the way through all of this thread, but skimmed through some of it, look at the pics through all of it & didnt see this layout so I will post it.
I have an LS2 (with LS3 heads) in an 86 Monte SS & want to put the Cadillac supercharger on it. I actually already have it. But I mounted the engine 1" back and don't want to redo that, I have the Holley AC compressor mounting it up high on the passenger side because I dont have room down low. I have debated this setup from LSXConcepts. Others have said there isn't enough belt wrap on the supercharger pulley. I will have to change AC bracket, they say their stuff wont work with the Holly bracket. Here is what their setup looks like:
#131
I think that setup is lacking in the belt wrap department. Maybe if the tensioner angled up, towards the supercharger pulley.
If you do use that setup, then never pulley down the blower, or belt slip will be unavoidable. To get more boost, your only option is an overdrive crank pulley.
#132
With that in mind I'd look at this or the GM Modified (which high mounts the alt) with the Kwik bracket to low mount the Sanden mini-compressor as the two best solutions on vette/lsa FEAD spacing. If I were doing over again I'd price both out completely and see what the differences is and decide from there. The complete GM modified FEAD is about $1k (alt and power steering, all tensioners/belts etc), plus $250 for the compressor and probably another $200 for Kwik bracket. Not sure total cost using the LSX parts?
#134
I have a couple other questions for you guys who have completed this swap.
1. What are you doing for a fuel system? Does this need a boost reference regulator since my understanding of the CTS-V fuel system has a PWM run fuel pump in it, and obviously, most of us won't be doing that?
2. Are these setup with a MAF card or are these built from the factory without a MAF? I haven't seen a MAF card on any of the pics I have seen.
#135
lsa blower swap?
My Fuel system
A1000 pump in tank -10 feed, -8 return (complete overkill)
Boost referenced aeromotive regulator w/ -6 line to fuel rail. 58 psi base pressure.
http://www.chevyhardcore.com/tech-st...h-fuel-system/
The factory lsa with e67 uses a round MAF similar to the trucks. I believe the connect and cruise kit uses the LS7 card style.
I have an LS7 card MAF but we ended up going SD because I have a 24x 0411 setup and we ran out of scaling at 5000 rpm.
#136
I used the GMPP LSA wiring kit which has the MAF sensor.
#137
RLJ676, do you have a running swap? I also have the Corvette filter setup, but it sure seems like without a boost reference FPR, or something else, just a base fuel pressure sounds like a recipe for disaster.
I guess the pics I have seen, don't show the MAF or something. I have a truck MAF currently for my N/A setup, but as ctsvcaddy said, I would think it would hit a "wall".
#138
I'd assume the only potential issue is if your injectors aren't big enough to flow what's needed at 58 psi. I'm using ID850's, but if wanting to make the 552 RWHP I did on stock LSA injectors at 58 PSI maybe there'd be risk. Both tuners I was dealing with prefer this to any sort of changing pressure setup, that's just another un-needed variable.
#140
Not changing fuel pressure is more of a variable. The reason why pressure is raised 1:1 is to counteract the boost trying to push the fuel backwards down the injector's throat. Flow shouldn't actually change as the pressure goes up with boost, it's reduced at idle because the intake vacuum attempts to suck the fuel out of the injector....
