New Hooker 1968-72 A-Body LS Swap System Preview
#262
#265
This pic will give you guys a better idea of the system geometry looking at it from the front of the car...both the 2-door and long wheel base systems share the same geometry all the way over the axles with the tailpipe geometry being the only major difference between them. The header adapter legs leading into the X-pipe are custom pieces that are shown here and are something I just made up for the owner of the wagon that was borrowed. It does show however how easy the systems can be adapted for use behind a SB or BB Chevy also.
#267
Will these headers fit in a 66 GM a body (gto) with the 12611hkr plates? With my setup in place and all components tied together, I don't want to go moving the engine forward or backward at this juncture.
#268
I really can't say either way old66tiger as I've not personally seen the headers on anything other than an LS engine mounted in 68-72 A-body cars using the new specific Hooker engine brackets developed with the headers. I will be embarking on the development of 66-67 A-body swap system here shortly, so new headers will be part of that effort if these do not fit.
#269
Todd,
I didn't even notice the clever way in which the crossmember is designed to mount. On my GTO crossmember removal is a pain because unlike Chevrolet crossmember, Pontiac used extra rubber isolators at the frame.
Andrew
Andrew
#270
Yes Andrew, I had to create a work-around for the crossmember mounting due to the installation constraints imposed primarily by the T56 and 4L80 transmissions.
#271
I have tried the Hooker long tube headers with my 1967 Pontiac GTO Convertible. we are using an LS3 create engine from GM and a T56 six speed. Also using a Quick time bell housing. We are using the stock trans. crossmember, but had to re-locate the mounting tabs on the frame for the cross member. The Headers hit the floor board and the oil filter. Also, the Quick Time flanges will have to be trimmed to allow the headers to fit. Regretfully, I sent them back.
#272
#274
Upon further evaluation, I believe you could use a center-inlet muffler on this system by modifying the X-pipe outlet legs, but you still wouldn't be able to use the center outlet unless you were going to run dumps on the end of the mufflers.
#276
Toddoky. Do you know how wide the transmission support bracket is? I am thinking of putting the Holley unit on my 65 Skylark. It appears to be a whole lot lighter than the one I have.
#277
Yes, it's 55" in overall length and 54" between the bolt hole centerlines of the mounting feet.
#278
Thank you sir, I have been worrying the toll free number for two weeks, and BIG thanks for putting all of this info and process out here on the forums for us to watch the progression.
#279
My pleasure ycgoat, I know if I was doing a swap I'd also appreciate having photos and similar product information that told me what the benefits and results of installing a collection of parts on my car was going to be before I purchased them.
