New Hooker 1968-72 A-Body LS Swap System Preview
#741
I have got a 69 Pontiac GTO i am puting a LS2 out of a 06 GTO i used the one inch forward frame mounts. it has a 4l60 transmission i got the stainless mid length headers part num# 70201309RHKR and adapter pipe part num#70701311RHKR. i am wanting to know if i can use my factory 1969 GTO cross member with stainless exhaust system, the part num# is 70501353RHKR,
#742
#744
#752
Nice.
Also, does anyone happen to know how much, if any, these Hooker engine mounts might raise or lower the motor as compared to the Dirty Dingo sliders? Just asking in case someone has used both. I either need to lower my motor a tad or raise my tunnel a bit to get driveline angles right. It's close, but I need another degree or two. Now that I think about it, modding the tunnel would be easier than pulling the motor, but anyway if anybody has info about heights I'd appreciate it.
#754
A standard 4-5 week production lead time applies to this crossmember as it does to all other Hooker crossmembers and I think we're about 3 weeks in from the order...as soon as I hear something I'll give an update.
#756
#757
I bought the crossmember and forward biased mounts for my 69 and installed new body bushings and i cant get the crossmember to even come close to fitting, the trans is topped out in the tunnel and with the trans mount on the crossmember hits the mount way before it will get on top of the frame.
#758
#760
Edit: the shorter height Energy Suspension mount is part number 3.1142
