1971 gt 37 pontiac lemans ls 1 6 speed swap
Old 11-12-2015, 10:37 PM
12NVRICH's Avatar
Default 1971 gt 37 pontiac lemans ls 1 6 speed swap
Project is almost finished ls1 engine with ls6 heads 580 lift cam, 48# injectors, fast intake & fuel rails, Edelbrock 90 mm throttle body, Headmen headers, 2 1/2 exhaust with electrical cut outs, 4:11 posi rear. functional shaker, heated seats, back up camera, heads up display on windshield. makes 415 HP with about the same torque # at the rears. Big brakes and coil overs are next I want to put it on a road course. 1 1/4 mile pass [spun bad off the line] with street tires 12.57 @ 115 mph
Attached Thumbnails 1971 gt 37 pontiac lemans ls 1 6 speed swap-gt-37-profile.jpg   1971 gt 37 pontiac lemans ls 1 6 speed swap-gt-37-profile-2.jpg   1971 gt 37 pontiac lemans ls 1 6 speed swap-gt-37-shaker.jpg   1971 gt 37 pontiac lemans ls 1 6 speed swap-72-gt-37-rear.jpg   1971 gt 37 pontiac lemans ls 1 6 speed swap-gt-37-1-engine.jpg
Old 11-12-2015, 10:47 PM
Project GatTagO's Avatar
Received 1,412 Likes on 891 Posts
Nice. Where did you get the idea for the shaker?
Andrew
Old 11-12-2015, 11:02 PM
gofastwclass's Avatar
Nice car, looks great.
Old 11-13-2015, 07:34 PM
12NVRICH's Avatar
Andrew
I saw this on a 1968 lemans carburetor car. basically cutting a hole in his hood and adding a shaker scoop on the carb.I knew form the git go I was going to use this on my fuel injection. I used a stock air cleaner base Welded the hole at the bottom (where it sits on the carburetor) completely closed and then sealed the the edge of the air cleaner off with heavy butaleane tape over to the edge of the paper air filter. Tape can be removed to service filter. I do not use the 14" lid so that area is open. It basically flows backwards. air enters the scoop through the flapper into the air cleaner base then through the back of the air filter and into the snorkel down through the tubing & into the TB. I removed the four screws that hold the fuel rails to the intake & replaced them with studs. The base is mounted to those about 2" above the intake I then I covered the studs with chrome water supply lines cut to length. The hood center section is a real Trans am hood fabricated to the Lemans hood so that it will seal. Whala!
Old 11-13-2015, 09:14 PM
Have a read...
https://ls1tech.com/forums/conversio...ion-2-0-a.html
Andrew
Old 11-13-2015, 10:37 PM
12NVRICH's Avatar
Andrew
Very nice, did the Pontiac die hards give you any flack? Most people have never heard of a GT-37 I get asked did Pontiac actually make this car? My answer yes they did just Google it, But they didn't make it like this. I see you are a TN boy too. Cool.
Old 11-15-2015, 02:17 PM
The Pontiac faithful hated me from the day my car first appeared on the cover of Popular Hotrodding back in April of 2004. At that time it had a 502 big block chevy in it, and it also had the shaker scoop.
I did the LS swap back in 2008 and the Pontiac faithful game me hell again. Good times...
Andrew
Old 11-10-2017, 04:12 PM
ssmith20's Avatar
any way to get measurements on the cut out of the hood
Old 11-10-2017, 05:15 PM
Who are you asking?
Andrew
Old 11-11-2017, 04:59 PM
ssmith20's Avatar
the guy with the blue 71 lemans was thinking about putting a shaker on my 72 lemans mine is identical to his but black with white stripe on side
Old 11-11-2017, 05:47 PM
cypris09's Avatar
Nice looking car . I pretty far from dropping in a motor and driving my 68 but I already get alot of hate mentioning that I'm putting a ls motor in. It's actually pretty sad how the die hard pontiac guys react to this news.
Old 11-11-2017, 06:04 PM
Received 3,037 Likes on 2,365 Posts
They just can't admit what a boat anchor the Poncho is compared to the LS
