LS3 in a Ford
Old 02-03-2016, 03:40 PM
aiiraciing's Avatar
Default LS3 in a Ford
Is it plug and play if I use a stand alone unit from the E-rod package into a stock GM cluster from a Vette or Camaro, if it matters it's going in my Ford?
Old 02-03-2016, 05:23 PM
joyridin''s Avatar
The E-Rod ECU uses the GMPP computer. I am quite sure you would not be able to hook it up to factory gauges as they say right in the instructions you cannot do it. They state you have to use aftermarket gauges.
Quick Reply: LS3 in a Ford
