LS1 Thermostat Housing
Will a generic Chevy aftermarket thermostat housing work or is the LS1 special? If it is, do you know of anyone that sells a straight in thermostat housing?
www.tunedport.com sells one with a swivel neck, though I'm sure it isn't cheap. Don't know of anyone selling a straight one.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 68ragtopLS1:
<strong> I believe the one from S&P is $95. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
_________________
Thermostat
www.speedwaymotors.com, www.summitracing.com, jegs.com etc
The LSx water necks have a counterbore that fits LSx thermostats; this is why the gen 1&2 SB Chevy water neck housuings may not work.
http://www.csr-performance.com/Merch...ry_Code=CP3SGC
It uses a standard small block Chevy thermostat, I just asked for one from a 350 Camaro. The thermostat fits slightly loose in the housing and it is supposed to in order to let a small amount of water get past for circulation. Been 3 years this month and about 10k miles with no problems. Using a 180 degree stat and that's where the motor runs most of the time.
Pat
http://www.rockauto.com/catalog/rafr...4-33939-283018
http://www.jegs.com/i/CSR/170/911LS1C/10002/-1
http://www.jegs.com/i/CSR/170/911LS1B/10002/-1
I'm just curious about the compatibility of a SB thermostat with an LS water pump.
Thanks!
