Power/charging system plans
I would run the ground wire all the way to the front and attach to the engine block. You may also want to add a power distribution point under the hood being fed by a 6 gauge wire front the starter post.
Don't forget to run the L terminal off the starter through your generator light or through a resister and the S terminal going to the power distribution block.
Andrew
Andrew
I should have include I was going to add a ground strap right to the starter.
You have a concern with that as opposed to wiring direct to the bat? Assuming you have a good clean ground to frame both places.
I am trying to keep engine bay super clean, so I place to run all wiring under dash, so not planning any connection points there. Still have the OEM PCM to control Alternator.
You can put the power distribution block inside, no issues there. Your OEM PCM only has the L terminal, right? If so, adding the S terminal will give your alternator load sensing capability and improve overall system performance as more accessories are turned on (headlights, wipers, cooling fan, etc....).
Andrew
I have always run a ground wire from the battery directly to the engine block. I can't state the technical reasons why, but a long time ago I read somewhere that using the frame or the body for a major load component like the starter is a no go...
Andrew
Andrew
I've always used one of the starter bolts as a ground AND a jumper from there to the frame/body with star washers. According to Ron Francis "Copper is the best conductor used in cars...lets say that 100%. Brass is only 22% and steel is 12-16%. " Won't go into atom valance shell electrical theory BUT your starter may be operating on 11 volts! Electronics needs pure power. You may get it there in style but choke it going back.
