Best fuel line kit option?
Any suggestions???
Thanks in advance
Most crimp tools can't crimp GM quick disconnect fuel (or transmission) fittings but I have one that does. If you can't, you can still use the J30R9 hose with the NICOPP line if fuel injection (smooth style) clamps are used.
http://www.tanksinc.com/index.cfm/pa...rod/prd453.htm
Thanks for posting that video...I think you helped me finalize my decision to use nicopp over nylon. Both materials have advantages but I like nicopp's ability to be bent and put where I want them run. I have braided stainless lines presently and they emit fuel vapor.
Question...what AN end fittings go on the nicopp line? Can I re use the existing ones on my braided stainless? If I could re use the existing AN fittings, I would only need to buy the 37 deg tool and the nicopp line. Thanks -Leon
NiiCopp is a dream to work with. Bends, cuts and flairs like no tomorrow. The only draw back is the price. It is much cheaper now than it was, but still not cheap.
I used compression fittings to go from the hardline to AN fittings (fuel only). Haven't had an issue in 9+ years. A lot of the compression fittings are only rated for 50 psi but many handle EFI pressures so shop accordingly. I am carb'd so russel and summit fitting worked for me.
I did see the tool much cheaper a few places but I agree...I will buy the rigid brand. I hate working with cheap tools.
Andrew
