What are the best LS swap mounts, 3rd gen
I'm getting ready to do a LS2 swap into my 88 camaro and was wondering, of those of you who have done this swap, what motor mounts do you think are the best all around and why.
What engine oil pan and transmission are you planning to use? Are you keeping/using the factory A/C evaporator case?
Well from what hear the 4th gen oil pan seems to be the best option, so most likely stick with that. I'm thinking I will keep the A/C system. Trans is a 4l70 from a Tbss.
That info helps you narrow your choices...using the F-body pan will force you to keep the bellhousing mating plane in the stock SB location, which will create interference with the stock A/C evaporator case. Some mounts are listed to fit 3rd-gens as well as G-body and A-body cars...don't believe it, the passenger side mount on a 3rd-gen application needs to have a slightly higher stand-off height than the driver side mount ( just like the stock SB clamshell engine brackets were) to provide proper engine alignment and a level engine in the engine bay.
Very good information. With that being said, whose mount would you recommend with that setup. Question 2, is there a better oil pan choice? I've heard talks of ctsv pan but they seem harder to locate. Also wondering if the adjustable mounts i.e. dirty dingo are worth it.
Mille, when you say stock clamshell, do you mean the original for the 3rd gen or the 4th gen. Many companies don't seem to specify whaT to use with their brackets.
Everything looks awesome, by far the nicest, cleanest setup I've seen. I do have a question regarding the transmission crossmember though. I already have a 4th gen tailshaft housing to accommodate the TA in its stock location, Is there another crossmember I can use or will exhaust clearance be an issue. If not, what do I do with the mount that sticks up on the hooker Crossmember. Oh, also the exhaust, do i have to use the complete catback system with the hooker headers or can something be fabbed up in the mean time due to budget.
The crossmember is an integral part of the swap system and provides the required exhaust passage clearance to fit the Hooker exhaust system, which no other crossmember available can provide.
A competent fabricator can modify any exhaust system to make it connectable to the collectors of the Hooker long-tube headers.
I used Spohn motor mounts and a custom made cross member that the torque arm mounts to (not the trans). I use my a stock 3rd or 4th gen length driveshaft. I believe the Holley parts will allow a stock driveshaft, but you should check.
Also used th fbody pan but had to cut my K member to fit. If I did it again I would use the Holley 302-2 pan so you don't have to cut the K member. Price is about the same on the pans.
Toddoky says that the hooker mounts have the higher PS standoff and maintain the original crankshaft centerline in the car. Not sure about other companies. The hooker kit looks the best IMO, my only issue is that the trans crossmember is a bit pricey @ $300, plus I would need another adapter bracket for the 4l70. Another $40. Also the holley pan is up there in price @$360 compared to the ls1 fbody pan around $200, but may be worth it in the long run due to clearance issues with the subframe.
Thats a great thread on your build 6Speed. Do you know if a can use the stock mounts from my third gen or do I need 4th gen mounts, look similar in pics but have not compared them in person.
Thanks Iroc12et.. if you mean the motor mounts that bolt to the block, the 3rd and 4th gen ones are different. I used 4th gen fbody mounts to my LQ4. The bolt hole pattern is different at the block. A good place to compare is on rockauto.com as they have the actual part photos.
