LM7/LS1 Swap into Chevy LUV
I'm new to the LS scene and would like to swap a LM7 5.3 into a 1981 Chevy Luv truck. The truck is already set up for a SBC and TH350. I'm planning to run a TH350 behind the LM7. My question is, what is needed to get the LM7 running? Wiring, PCM, cats...?
For those of you that have swapped a LS motor into an earlier model car I'd appreciate your input.
Thanks ya'll.
Thanks ya'll.
https://ls1tech.com/forums/conversions-hybrids/1205046-5-3-luv-truck.html
Hope this helps!!
Hope this helps!!
Restricted User
I use these cheap mounts from Summit:
https://www.summitracing.com/parts/ani-2142
$3 each. Then some cheap adjustable ebay adapter plates for like $35, and the engine is mounted for less than $50 using the stock frame stands.
Not sure where tho get the mounts quite yet. The truck is already set up for a SBC so it didn't seem too difficult to find LS motor mounts.
Our plan currently is to mate a TH350 to the LS motor, truck is set up for a TH350 too. Unlike the 4L60e that is included in the wiring harness, how do you delete that for just the LS motor?
