Cruise not not working
The cruise in my LS swap into my 68 cutlass is not working. I have good power and ground coming into the cruise control module but the hp tuners scanner is not showing the cruise module as "on". It is a drive by cable and I am using relays with an aftermarket control switch. Eveything apears to be working properly when tested with my test light.
Im using this switch. https://m.summitracing.com/parts/rpc-250-3032
Wired like this. http://67-72chevytrucks.com/vboard/s...d.php?t=398006
Seems like i should atleast see the scanner telling me the cruise module is on.
I have confirmed that the ground, key on power, and the cruise control on power is good... Next I guess I will try grounding the cruise inhibit signal which should bypass it? It is currently hooked up thru the pcm.
No LED brake lights.
Thanks for the help. It ended up being the tcc/brake switch being slightly out of adjustment. The brake switch portion was applying power when the brake was pressed but there was no power supply when not depressed unless i pulled up on the pedal. Works like it should now!
