Stock 6.0L power steering pulley
Can anyone verify if the Dorman 300-201 power steering pulley will work on my stock steering pump? This unit had the hydroboost type brakes, with the one pressure line and two return lines. I am using this smaller pulley to clear the steering box.
Can you post the two diameters you are dealing with (original pulley and smaller one)? I have an LY6 and would like to use a smaller pulley if possible for steering box clearance as well.
Will you need a smaller belt or will the tensioner take up the difference?
Thanks!
Joe
Thanks!
Joe
OK, so I go the 300-202 pulley and it doesn’t line up with my other accessories. It’s pressed on flush......
Assume the LY6 “van” accessories are different from what you used?
Bummer.......
Bummer.......
