Stand Alone Harness Question (Mystery Wire)
So this harness has been running as a stand alone in another swap car, but i was going through it and re-doing the routing and loom. Then i found this Resistor? and one wire is cut, while the other runs back into the main harness. This was wrapped in with all the grounds in the passenger bank of injector and coil wires.
Looks like the harness and computer are out of a 2004 GTO LS1.
Im sure im not searching it correctly but i cant seem to find anything about this thing.
What is it? Do i need it? Can i remove it all? Etc...
Thanks
Thanks
