Yet another '72 short bed build....
#221
BlueMaxCougar and Cheese Weasel nailed my thoughts! The colors are not what I would have chosen out of the blue. But they FLAT WORK!
And as far as the stance, the numbers above will set things right to my eyes. NICE WORK!
#222
Thanks for the info and the pictures on the compressor AC lines. I am planning a swap into an '84 this summer and have always liked the way your lines come out on your builds.
#224
[QUOTE=ls1nova71;20072412]Door panels all cleaned up and installed.
Then got the tires and wheels all mounted up! cant wait to put them on so I don't have to look at those crappy rollers any more!!!
They are US Mags Ramblers, 20x8 in the front and 20x9.5 in the rear. Couldn't wait to see what they looked like so threw one on the front real quick for a sneak peek. I like them!
I’ll take one of your books. Nice build. What are the off set on those wheels. Man this is really turning out very nice. Always love that color combo don’t se that around much.
#225
[QUOTE=ls1nova71;20072383]Yeah, I took some pics, but didn't post all of them. Anyway, the compressor fittings are made from factory lines with barbed fittings TIG'd on the ends. The low side is the original compressor fitting with maybe an inch of the original line left on it and a 45* fitting welded to it. It clears the frame with very little trimming required, but the down side is in order to keep the #12 hose straight, the fitting curves over the top of the bolt hole. The bolt goes in with no problem, but you can't get a socket on it to tighten it, you have to use a wrench, but that's not a big deal to me since it isn't something that gets taken off a lot. The other side of that hose is a factory low side line that comes out of the accumulator which has a straight barbed fitting welded to it. You can see them in this pic if you really look.
The high side line is something I have been doing for years, and works super slick! It is a line off of the condenser of a 99-07ish Tahoe, Suburban, or any other of those kind of SUVs. Trucks don't use the same lines for some reason, so it has to be from an SUV. I then had a barbed fitting welded to the end and bent the line to clear the frame. Again, you have to tighten it with a wrench because its under the frame rail, but it clears perfectly. The modified line is on top, with an unmodified, straight from the junk yard one on bottom in this pic.
It's hard to get a decent pic of them installed in the truck, but this is what they look like when all is said and done.
You can see where I slightly trimmed the frame for the low side line clearance in the last pic, and it looks like it is hitting it from that angle, but its got plenty of clearance, its just hard to get a pic of it.
The attention to details are shown on this truck just by those hose clamps. I’m also **** about the way my clamps are facing and how level the are. Very nice.
#226
#227
Getting real close to wrapping this thing up. Got the seat installed so the interior is just about finished up, if only I could find the bezel to the Alpine.... Oh, and need to change out the aux cable mess that's hanging down under the dash...
This pic reminds me of a brochure picture. I love the Custom Deluxe seat!
On the front fenders where they used to have emblems that said 8-350, I added some Vortec emblems off the hood of a newer truck. I'm so used to there being an engine designation under the marker that it looks funny without anything there so these fit the bill pretty well I think.
I actually drove her around the block today, open manifolds and all! LOL! Took some better pics in the street to see how the stance was. This pic is just about the same spot where I pushed the bare frame out last summer.
#228
I swapped the 4" drop springs out for a set of 5" drops and I think the back looks better, but the front needs to come up about 1/2" to 3/4" or maybe even an inch to look a little better. Not sure how to do that with any degree of accuracy though... I have a set of V8 springs I can put in it, but then will have to trim to get it right, and that could take several attempts, not fun on a coil spring front end.
After my drive around the block, I vacuumed the A/C down but only had one can of R134a, so its still not done, will have to get more to finish it up and see if the air works. Would probably help if it was a little warmer out too, hard to tell if the vent temps are cool when its only around 55* outside.
#234
I guess since this truck is basically done, its not going to hurt the thread if it goes off the rails a bit... Now, don't anybody take it personally, because I get it, when people see Trucksters they think of me, but if I see that damn car one more time I'm going to have a melt down! LOL!!! That car sold for what it did because the guy who built it has connections. The auctioneer said it was built specifically for Beverly D'Angelo, which I'm pretty sure was total BS. The builder just had her there to sign it and to make it more appealing, as that's his deal. He builds replica movie cars and then has someone from the movie be on hand when it sells at auction, he's done it many times. But the worst part of that car is how inaccurate it is, I mean even the color is way off! The trim is not in the right locations, its all squared off and not rounded like it should be, the vents on the quarter panels are totally wrong, and the front bumper wasn't modified at all!! Its like they didn't even look at the movie car when building it..... Anyway, I'll stop my rant now, but just for kicks, here are some screen shots from the movie, pics of my car and then pics of the BJ car, I'll let you all decide if it was truly worth almost $100k.......
#235
Can you give me a quick run down on the motor in the truck?
#237
I agree with your rant and thought the same thing while watching the video and said "wait a sec, this isn't right..." so many times he might as well have just called it a custom and not a replica. I literally think it sold for what it did because of a few autographs and a signed story from one of the people in the movie. WTF.
Back to topic.
I got to see this truck completely assembled and running for the first time Saturday and all I can say is holy cow this thing is WAY NICE! Just like all your builds it attracts a crowd wherever it's parked. If you think it looks good in pictures, you really need to see it in person, the level of detail and finish work is just amazing.
Ironically yesterday I saw an un-restored C10 in the same livery and thought of this one.
Back to topic.
#239
Back to topic.
Back to topic.
#240
Anyway, got the exhaust done Saturday morning.
Took this pic just because I thought it looks cool with the rear sway bar...
Left side just about done.
Then loaded up on my buddy's trailer for the ride home.
Once I got it home, I drove it to the gas station and put about half a tank of gas in it, then just drove it around some, went by another buddy's house to check out his project then came back home. Everything seemed to be doing good so I decided to take it to the cruise night in Belton MO. That's about 30 miles one way from my house, so it was a good shake down run.
After the show I drove home the long way and other than the rear brakes wanting to lock up before the front when stopping real quick, and the front end needing a little more work in the alignment, it drove great! Put about 90 miles on it Saturday. but, then the weather went to crap and I haven't had it back out since.... Hopefully the weather is better by the weekend....
I'm pretty pleased with the way it turned out, and although I didn't make some timeline goals I originally set out to make, I think I did alright, started it April 19 2018, and took it to its first show April 27 2019.
