Square Body Crew Cab Dually 454/NV4500....considering a LS Turbo Swap
Old 06-06-2019, 11:20 AM
Ford_Assassin's Avatar
Default Square Body Crew Cab Dually 454/NV4500....considering a LS Turbo Swap
Hey guys, I have a mild 454 mated to a NV4500 in my 1988 R30 dually crew cab. It has an Edelbrock Performer TBI intake, Airaid TB Spacer, Thorley ceramic coated Tri-Y Headers, dual 2.5" into 3.0" exhaust, and SuperChips chip (unknown specs).
I get 14 mpg now highway, 10 city, 8 towing, but I am considering swapping in a spare/fresh 5.3 (that I already own btw) into it and retaining the NV4500 along with an eBay GT45 turbo too.
I tow about 6 times a year, my 30' travel trailer weighs 7500 lbs. I have done no less than 20 LS swaps, almost all of them with a turbo.
Thanks!!
Old 06-07-2019, 11:08 AM
hokeplaya05's Avatar
i would lean towards a 6.0 for the added torque for towing, but i guess adding a turbo to the 5.3 will help in that department.
The following users liked this post:
Ford_Assassin (08-04-2019)
Old 08-04-2019, 11:45 AM
Tuskyz28's Avatar
I like a 454 Vortec over the 6.0 LS motor for towing. My 97 model truck with a 454 Vortec pulls like a animal... plus big block parts are cheap.
Old 08-04-2019, 11:48 AM
Received 3,025 Likes on 2,356 Posts
I have to agree with Tusky. A big block, WITH EFI AND coil on plug ignition would kick butt on towing.
Old 08-04-2019, 12:35 PM
Being you're in California you need to keep it smog legal. Don't you need cats on it?
Old 08-04-2019, 12:37 PM
Talking
It never had cats on it from the factory, besides I live in Amador county.....no biannual smog testing here.
Old 08-04-2019, 07:34 PM
Ahh, nice! You are off the hook then!
Old 08-05-2019, 07:46 AM
243's Avatar
I was goint to suggest a 6.0 over the 5.3 in the white beast, the 6.0 in my 2500HD tows fantastic but my average mpg is 12.0 unloaded.
Awesome tow rig!
Ford_Assassin (03-09-2020)
Old 08-06-2019, 12:10 AM
CattleAc's Avatar
I ran a 454/sm465 combo in this before swapping over to a 6.0L/4l80e...
Best decision I ever made...better mileage, at least as much power, I may have sacrificed some torque, but the mileage and driveability far outweigh that.
Ford_Assassin (08-06-2019)
Old 08-06-2019, 12:16 AM
Nice ride dude. I think I will do something similar.
Old 08-06-2019, 12:58 AM
CattleAc's Avatar
Nice ride dude.
Right back at you...
What are you running for gears??
Old 08-06-2019, 01:04 AM
3.73's. Rear is c notched, boxed frame, bagged with compressor, rear sway bar, and rear disc on the stock Dana 70HD. Unknown posi/locker, but it lays down 4 deep/solid stripes if needed. The NV4500 is nice to have too.
Old 08-06-2019, 07:00 AM
Tuskyz28's Avatar
All 454s are NOT the same. Some/most are pretty weak from the factory. The Vortec 454 is one of the most powerful ones that was ever made. The downside is they only made the Vortec 454 from 96-2000 it features a factory hydraulic roller setup. The TPI 454 is one of the weakest and it featured a flat tappet setup.
Old 08-06-2019, 07:45 AM
Restricted User
JoeNova's Avatar
This. A lot of this.
Old 08-06-2019, 10:34 AM
CattleAc's Avatar
Well, I had the last year of the 7.4L carbureted models...so it was a real pooch. As limited as the TBI's were, they really shined compared to this...
That being said, still the best option for me was an LS swap...
Old 08-06-2019, 11:13 AM
Tuskyz28's Avatar
Sound like you had a flat tappet 454 model motor which were pooches. My 97 3/4 454 Vortec is one of the top dogs due to the factory hydraulic roller valvetrain. The owner before me bought the truck brand new with 4.10 gears in a 14 bolt rearend and a 4L80E transmission. Im the 2nd owner of the truck. It was a farm truck that used to tow John Deere tractors on a gooseneck trailer. The gooseneck setup is still in the bed of my truck. Ive towed my Camaro on a 20ft trailer a couple of times. I have a hard time telling the car is back there under acceleration but i admit it could use a brake upgrade in my opinion.
Ford_Assassin (08-07-2019)
Old 03-09-2020, 01:06 AM
Moving forward with this with 6.0 LQ4. Engine received LS9 head gaskets, new LS7 lifters and trays, Summit mild tow/truck cam, BTR single valve springs, stock truck decapped and flow matched injectors, and GT45 turbo. Only looking to make 6-7 psi, but should yield better mpg and retain towing ability.
G Atsma (03-09-2020)
Old 04-23-2020, 04:20 PM
Old 04-23-2020, 04:46 PM
Chocolate Apocalypse's Avatar
Nice! Curious, what exhaust manifolds are you using? Thanks!
Old 04-23-2020, 07:39 PM
Stock driver side manifold, crossover to a cast log manifold off eBay/Amazon (no longer available it seems). Looks like a KB Racing style, no where near the quality. Spent 4 hours with carbine tools cleaning up all the casting flash and spark plug wire boot clearancing.
Quick Reply: Square Body Crew Cab Dually 454/NV4500....considering a LS Turbo Swap
