Low mount AC closest to the block?
Old Jul 11, 2019 | 11:58 AM
samckitt's Avatar
Default Low mount AC closest to the block?
Who's brackets keeps the low mount AC compressor closest to the block? And/or is the factory low mount AC compressor smaller than aftermarket? I have an SD7 with Holley's brackets, not yet installed yet, wondering if there is something shorter and closer to the block so I don't have to notch so much of the front crossmember. Yeah I know there is the high mount brackets, looking for something mounted low on passenger side.
Old Jul 11, 2019 | 04:02 PM
dlwilson's Avatar
I haven't used it yet, but the Alan Grove Components brackets appear to be the closest ones.
Old Jul 11, 2019 | 04:55 PM
Michael Yount's Avatar
Here's where an Alan Groves low mount with Corvette spacing ended up on mine....
Attachment 713137
And, when finished -- not much at all shows from the top.
Attachment 712560
Old Jul 11, 2019 | 05:06 PM
jlcustomz's Avatar
Bought some from BRP years ago. Silver painted steel.
Old Jul 11, 2019 | 05:46 PM
gtxracer's Avatar
Supposedly these are small and compact but I've heard mixed reviews about them...
https://www.dirtydingo.com/shop/prod...oducts_id=1720
Old Jul 11, 2019 | 06:01 PM
Project GatTagO's Avatar
I believe the Holley low mount work on a g-body without frame modifications. Double check their installation guide.
Andrew
Old Jul 11, 2019 | 06:27 PM
jmd's Avatar
jmd
Truck, in truck offset, to answer your question.
Old Jul 11, 2019 | 07:09 PM
user 4737373's Avatar
Truck and F-body offsets to be precise; the Corvette offset is the only one that cannot be accommodated in the G-body application when using the Hooker Blackheart G-body LS swap engine mounting brackets.
Old Jul 11, 2019 | 08:24 PM
JoshHefnerX's Avatar
The G8 mounts the AC down low. It's a different offset from the vette or fbody.
Old Jul 11, 2019 | 08:41 PM
My recollection is the G8 and Corvette are the same. This seems to agree with that - https://www.lsxconcepts.com/pages/wh...fset-do-i-need
Old Jul 12, 2019 | 05:45 AM
LS1-IROC's Avatar
That is the mount I was planning on using...what have you heard bad about them?
Old Jul 12, 2019 | 07:59 AM
samckitt's Avatar
Andrew
It does *IF* you are using their motor mounts, & with F body or truck spacing. Throw 1" back mounts & Corvette spacing & then it wont work. Trying to put LSA SC on it with stock belt setup.
Old Jul 13, 2019 | 09:11 AM
jlcustomz's Avatar
Scot, I'm guessing you're trying to fit this in a g-body? I did my 99'F-body LS1 swap back in 02' before all the swap stuff we got now. Started out with the factory ac compressor. Cut & reboxed the frame in front of the idler arm for extra clearance. Also had to notch & box in the crossmember for backside ac compressor. After 2 factory variable compressor failures, switched to a sanden & the available BRP mounts to not have to make something in assembled vehicle. The sanden is smaller & now has more clearance room.
The point here is this is hot rodding & done correctly, there is nothing wrong with cutting & reboxing in frame & crossmember for some clearance to do things the way you want with the products you want or have.
I love having the ac compressor down low for looks, actually had someone argue with me that I needed ac.
Old Jul 13, 2019 | 09:48 PM
jake-'s Avatar
I run this setup Worked fine for me.
Old Jan 3, 2020 | 08:48 AM
Houston_t's Avatar
Did you ever find a solution ? I bought the holley mount kit for my Grand National and i am trying to figure out the same thing, im doing a LSA supercharger also. With the holley mounts is there enough room to notch the frame for ac before you would hit the mount ?
Old Jan 4, 2020 | 08:55 PM
Theduck's Avatar
I'm using brackets from a company called OLD AIR. It puts it tight and uses the back grooves on the truck pulley .
