Tensioner Indicator
https://documents.holley.com/199r10616rev3.pdf
The pic below is one I took back in 2016 during the build, I don't have a decent picture of the tensioner indicator and it's not really visible now...
Sanden 508/sd709 compressor, Holley kit and all other stock accessories.
I tried to fit the K061130 but holy cow is it a tight fit, couldn't get it over the tensioner so returned it for the next size up. Going to attempt it again Thursday and putting it over water pump last and rotating engine to pull it on that pulley.
Just hoping you remembered if you had a bear of a time getting that belt on and if you are running the 145a alternator as well. Only other thing I can think of is going to a 76mm idler pulley right below alternator to give me little bit of extra slack I need to get the K061130 on.
Holley said to run the tighter belt, but with that 90mm pulley I am afraid its going to max out the tensioner and cause the belt to chirp/pop off.
With the K061140 it is slipping under hard throttle, same exact accessory setup as shown in your picture.
