Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts
Does anybody have an idea of how much all these parts list for- the grand total for the c5 kit? I'm not really interested in the price on the ac stuff, but someone else may.
Thanks
Thanks
Originally Posted by Zedzag
Some F-body stuff.
I went down to my local GM dealer and "commondeered" their computer. Here's what I found...these are all F-body applications.
Alternator:
Rear bracket P/N 12556915
Front bracket P/N 12563327
Power steering:
Main bracket P/N 12561584
Front brace P/N 12555693
These part numbers are right from GM's computers and they also list all the idlers/tensioners as well as the mounting hardware (which I'll get later)
Hopefully these can help others out.
Alternator:
Power steering:
Thanks
Thanks
I switched from the low alternator, camaro, to the high mount vette setup. I did this because .... I mounted my engine as far back as i could with the S&P type mounts and I will be using the BRP front rack kit hence, the alternator would hit the rack if it were low mounted.
BTW, the vette alt can be had online for $120 through Advance Auto Parts. And the vette power steering pump (if you need it) is $80 at Autozone. Both have a lifetime warranty. The camaro power steering pump is a different pump than the vette, a thicker shaft diameter if i remember correctly.
And the guy that said his power steering pump pulley was touching the foward boss of the top a arm is/was correct. I also had this problem...for alittle while...
If the motor is mounted with the BRP mounts there is no issue as the pulley is now forward of the a arm boss. But with the S&P mounts the pulley is in line with the a arm and a little torque is sure to shread your belt against the a arm.
You could either grind down the excess , and I do mean excess, metal on the boss that interfears, or do what i did and slap on a set of tubular a arms.
ChrisP
Originally Posted by chrisp3
i just went through this myself. I will post the prices i got off of gmpartsdirect. I hope you have "MS Word" in order to read it. I took these prices to the local gm dealer and they matched them and had it all in stock..(shocker!)
ChrisP
ChrisP
Andrew
LS1 LS2 Vette brackets
Anybody know what all difference there is in LS1 and LS2 Vette accessories?
I mocked my 85 Vette using a C5 motor. I switched to a crate LS2 and am now probing out the accessory systems.
One thing I know, the a/c compressor on the C6 LS2 has a SIDE port for the maifold in the rear. The C5 LS1 is a rear port. To reuse OEM accessories in a 84-96 Vette, you have to use a REAR port a/c compressor.
With that said, I don't yet know if the compressor mounting bracket is different too.
If I find this out before answering, I'll edit the post with the info. Otherwise, PLEASE chime in if you know.
Here is my parts list for LS2 GTO accessories. The F-body LS1 alternator brackets are listed because the GTO alternator is stupid expensive.
Edit: The prices are with a 25% discount, you might be able to get the same from your dealer if they know you'll be buying several parts.
Part -GM # -GM Cost
Fuel rail O-ring kit -89017587 -$28.95
Fuel Rail -12572174
Fuel Injectors(8) -89017586
Fuel Injector Retainer (8) -24503227 -$13.04
MAF -25318411
Starter -92169668 -$280.22
Water Pump -89018034 -$236.33
Power Steering Pump -92161580 -$259.74
Power Steering Reservoir -92176477 -$47.09
Power Steering Bracket -92066673 -$26.60
Power Steering Bkt Bolt -92138830 -$5.76
Power Steering Pulley -92066499 -$45.02
AC Compressor -92175482 -$451.61
Compressor Bracket -92066950 -$48.89
Compressor Bkt Bolts(6) -11515771 -$19.14
Compressor Bkt Bolts(2) -92138526 -$22.70
AC Lower Belt Tensioner -12560345 -$59.83
AC Belt -4K430
Drive Belt -6K785
Pulley, Top Idler -12557335 -$31.73
Drive Belt Tensioner -92111701 -$37.64
Drive Belt Tensioner Bolt -92138257 -$8.50
Drive Belt Idler Pulley -12563326 -$36.68
MAP -16212460 -$62.50
FAST Intake gaskets -30-54009-8 -$31.40 (from FAST)
FAST throttle body gasket -30-54011 -$9.27 (from FAST)
Fuel Rail Cover, right -92066954
Fuel Rail Cover, left -92066955
LS1 F-body Oil Pan set -12558762 -$199.79
Oil Pan pick-up tube -12558251 -$33.91
Oil Dipstick -12551581 -$9.99
Dipstick Tube -12551577 -$7.04
Oil Deflector -12558253 -$17.83
LS1 Alternator bracket -12563327 -$15.66
LS1 Alternator bracket -12556915 -$11.53
Upper Rad. Hose -10271554 -$30.48
Lower Rad. Hose -10271555 -$18.41
Steam Tube -12556452 -$10.55
Part -GM # -GM Cost
Fuel Rail -12572174
MAF -25318411
AC Belt -4K430
Drive Belt -6K785
Here are the details for GM Parts new C5 Acessory drive kit:
Corvette C5 Accessory Mount Kit From GM: PN 19155066 (19155067 for LS2/7) ~$675 Dealer Cost
12572188 Serp Belt
12569528 A/C Belt
12568181 Tensioner
12560345 A/C Tensioner
12557334 A/C Idler
1137031 A/C Compressor
12556444 A/C Compressor Bracket
15261472 P/S Pump (Reman)
12555222 P/S Bracket
12578068 Alt + P/S Pump Bracket
12555693 P/S Pump Brace
12559890 P/S Pump Pulley
10353440 Alternator
26046502 P/S Reservoir
12572188 Serp Belt
12569528 A/C Belt
12568181 Tensioner
12557334 A/C Idler
10353440 Alternator
#32
n00b request here: it looks like there are a couple of kits listed here. can anyone append pictures of each setup for future reference? i think it would be generally helpful and cut down on questions from others.
meanwhile - John - since you're looking, i'd like to take a sec to say 'thanks' for keeping your personal 'swap progress' website online, it helped me a LOT throughout my swap.
#36
CTS-V oil pan and related part numbers
CTS-V
12598152 Engine Oil Pan/Reinforcement $131.33 S&H $28.89 Total $160.22
12584737 Stick $7.48 S&H $2.00 Total $9.13
12584738 Tube $9.07 S&H $1.65 Total $11.07
12577906 Screen $44.67 S&H $9.83 Total $54.50
12611129 Deflector $15.30 S&H $3.37 Total $18.67
Subtotal: $253.59
part numbers and prices have been verified on gmpartsdirect as of September 2007.
thank you to everyone who helped me get all the part numbers.
Subtotal: $253.59
#37
I guess I got a good deal on my engine 5.3L with nearly complete corvette drive system and all accessories....$500
Anyways...I need to get a new crank pulley bolt (with the above combo) what is the part number I should get....I think there are 2 lengths.
#39
Wil this kit also work with the new LS3 + hotcam crate engine?
and can I just leave out the AC stuff when installing it?
Thanks
Peter
Thanks
Peter
12572188 Serp Belt
12569528 A/C Belt
12568181 Tensioner
12557334 A/C Idler
10353440 Alternator
12572188 Serp Belt
12569528 A/C Belt
12568181 Tensioner
12557334 A/C Idler
10353440 Alternator
