Can I JBWeld a 6AN fitting to the fuel rail??
I was thinking, can i just cut off the rubber lines coming out of the rail and just JB weld a fitting to the rail? Its been a real pain getting this fuel line hooked to it so far.
Re: Can I JBWeld a 6AN fitting to the fuel rail??
https://ls1tech.com/ubb/cgi-bin/ulti...;f=21;t=000264
here is more info on it.
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=001721
hope this helps, if you dont want to use these, have then brazed on, i would not trust JB weld with 60psi of gasoline behind it.
Ryan
Ryan
Here is what I used. Works great so far.
<img src="http://www.jegs.com/photos/7993923_22.jpg" alt=" - " />
Jegs part number 799-639210 $6.99
<small>[ April 02, 2003, 09:37 PM: Message edited by: Lesrace82 ]</small>
