LS1 S14 240sx Swap
#201
Originally Posted by Preston99WS6
i know this may be a dumb question, but what about power seering?
easy. take the stock gm line, take the nissan line, and just put them together.
i woudl offer to get the fittings and measurements, but honestly i will forget to ever do it. its easy though, just take both lines to a hose shop and they can put them together, just make sure you tell them how long you need it.
#203
What radiator besides hinson will work ? Im thinking a ka koyo aluminum s13 radiator should work b/c it fits with out modification , has inlet outlet on the pass side ls1 water pump is on that side so pluming should be easy but will it be enough to cool the ls1 . its only 2 1/16 thick
#205
the hinson radiator dont keep the engine cool? how thick is the core ?? i seen your car and lukes fd up close and the radiator seems big enough to do the job . i figured a universal alumuminum radiator with inlet outlet on the same side 2.5 thick core should work ? and keep the hoses simple . only problem is they dont really make any in 26with x 14~15height. or at least i havent found one
#206
i dont know, something isnt right in my cooling system and ive replaced every item but the radiator. i know their FD kit works fine but its the last possible problem on my car. and the headgaskets arent blown
#208
another thing im wondering in relation to your setup and mine is the height of the motor.
the hinson kit lowers the subframe, but the mounting system still has like 2'' gap between the oil pan and the motor, even with the stock intake manifold it would still stick out the hood. what im wondering is if possibly the top of the radiator sits lower than the highest water passage in the motor. but i dont know how sound that theory is, ive topped it off even with the front of the car raised 3' in the front, so i really dont know.
on a side note, thats a damn clean engine bay. mines getting there. i need valve covers bad.
#209
thats good to hear .. i wasnt shure if it would work out on the v8 . so you dont have any issuse at all . sitting , driving up hill , doese the temp fluctuate or stay pritty much even ..
#210
if the koyo can keep the higher strung turbo four cool then the V8 shouldn't tax it too bad.
#215
Originally Posted by datboibrad
ah. you make a good point man. hopefully by the time i get my project off the ground a half decent solution will have been found.
what about the set of headers that are really short and run log style and dump tward the very back of the motor. i honestly have no idea what model ls1 headers they are but i want to say they are the stock z28 ss or ws6 headers.
#216
Originally Posted by mmdb
aw man that's not good. How bout edelbrock (sp?) headers? I need something that'll pass emissions in CA. They're one of the carb legal ones out there for the LS1. Btw, what portion of the steering column is hitting the exhaust? Should i look for headers that hug the engine as close as possible? I'd hate to do any modification to the headers to make it fit.
I'm currently trying to get a set of C5 Manifolds to fit in my swap for I to need to pass a visual inspection for emmisions in GA here. (I've got pictures up in the thread I started titled 'Project 346SX...') I might get a set of long tubes made later but for now the manifolds should work okay. It's still pretty tight fit but the '07 to '00 C5 Manifolds are stainless steel so they can be welded on pretty easily. Make sure though that they are the ones that are welded together if you do buy or get a set from somebody for I'm not 100% sure which years got the stainless manifolds.
HTH!
#218
also, has anyone else tried running the rb x member? and to the guy that did (Slo_240sx) did you have to cut up your subframe any? it looks like you did a bit in your pictures just not really sure.
#219
Originally Posted by owen v8litew8
r u serious?
if you are glad I could help
if youre joking, uh, it was just an idea...
how is this done? do they just put spacers between the frame rail and the acutal subframe?
#220
pretty much.
