ls1 w/ EDIS8 and megasquirt
Old 05-16-2006, 09:06 AM
chevrev's Avatar
Default ls1 w/ EDIS8 and megasquirt
if i run my ls1 with an EDIS 8 and megasquirt setup would i elimintate the need for the cam and crank sensors since the timing will be controlled by the 36-1 gear and VR sensor? what other sensors would be left that would be neccessary with this application? here is what i can think of, if i am leaving some out please let me know:
temp, map, knock(2),throttle position, idle air control...
any others??? o2 sensor? oil sensor, etc...???
thanks,
shad
Old 05-16-2006, 12:49 PM
Brains's Avatar
Yes, if you swap to the VR and 36-1, no need for the LS1 sensors other than to plug the holes
Old 05-17-2006, 11:25 PM
under pressure's Avatar
Default LS1 and EDIS8 contol
Were you thinking of fitting the trigger wheel to the balancer? I was wondering if you have to key the hub in some way to make sure it does not move? Sounds interesting. Thanks
Old 05-19-2006, 08:48 PM
350SS's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/246852-can-i-fire-stock-coils-external-ground-source.html
Quick Reply: ls1 w/ EDIS8 and megasquirt
