ls1 w/ EDIS8 and megasquirt
if i run my ls1 with an EDIS 8 and megasquirt setup would i elimintate the need for the cam and crank sensors since the timing will be controlled by the 36-1 gear and VR sensor? what other sensors would be left that would be neccessary with this application? here is what i can think of, if i am leaving some out please let me know:
temp, map, knock(2),throttle position, idle air control...
any others??? o2 sensor? oil sensor, etc...???
thanks,
shad
thanks,
shad
LS1 and EDIS8 contol
Were you thinking of fitting the trigger wheel to the balancer? I was wondering if you have to key the hub in some way to make sure it does not move? Sounds interesting. Thanks
