where do you mount your ECU in your lsx mustang?
so im having a hard time doing the harness and finding a place for the computer. the ecu will be to close to the turbo if i leave it up front. any idea? maybe inside the car with a hole drilled through the firewall?
i am going to rewire the whole ecu to remove all the unneccessary plugs and such so i can lengthen some wires if need be.
here are the pics..
here are the pics..
I put mine in the same location that the factory computer was located . I ran the harness through the factory grommet too. You will have to trim the plastic mount for the pcm to make it fit. It is a pain in the *** if you keep the heater box, but it will fit. I had to shift the whole box over about 1''
