Gear Reduction LS1/LS2 Starters
Old Oct 13, 2008 | 08:41 PM
BBPanel's Avatar
Veteran: Marine Corps
Originally Posted by Carshopinc.com
From what I have seen, the starters will not work with ls2 t56 combos.... I have not had a ls2 t56 to mock up with yet... I have bolted them to ls2 and ls7 engines on a stand.....
Which starter(s) are you referring to? There are several starters being discussed here.
Do you know which starter(s) will work for the LS1/GTO T56 combo - that seems to be the primary issue through this thread? Thanks. -Bob
Old Oct 14, 2008 | 09:38 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
The units I carry.... I need to update my page but they do not work with the gto trans
Old Oct 14, 2008 | 11:05 AM
Jeff Smith's Avatar
I was about it so I called/ discussed with CarShopInc. There t-56 has two different (Camaro and GTO). Glad, I use Camaro T-56 6speed manual attached to LS2. I am going to order this one asap.
Thanks to CarShopInc.
Old Oct 23, 2008 | 09:38 AM
BBPanel's Avatar
Keeping this alive - I think there are still unanswered questions about engine/trans combos and what works.
Old Oct 27, 2008 | 07:05 PM
BlackwidowZ's Avatar
Originally Posted by BBPanel
Well I thought that originally because I thought the LS1 bolt pattern was not offset and the LS2 is. But it would appear all LS series are offset - perhaps someone can confirm that. My starter, which I thought was for an LS1 (I had it bolted up before mounting the trans) must be for some other combo because the mounting flange the bolts go through is too tall for my LS1 block-GTO T56 and the nose is too big as well. I have googled and run the p/n and come up with nothing. That's what is confusing because all of these aftermarket starters (and the GM p/n 10465385) say they are for the LS series, they don't differentiate between any combination - perhaps they are backward compatible?
just go tmy ls2 gto starter.. mated it to my ls1 and ls2 bell and it fits perfect . i can take pictures later
Old Oct 28, 2008 | 08:19 PM
Grve66's Avatar
What starter did you end up getting? I am Having same issue. LS2 with GTO T56
