How low is too low?
Old Oct 14, 2008 | 09:33 AM
6spdgto's Avatar
Originally Posted by 68rustbucket
Your car is hung like the hedgehog!
Even if you raise the engine oil pan, take a look at that tranny pan, it's about as bad. Can you not raise the entire engine a bit?
Old Oct 14, 2008 | 03:24 PM
Rodder's Avatar
Moroso, Champ (Autokraft, CarShop), ATS, and probably a couple of other people all make nice custom pans for the 1st gen Fbody that will clear the stock rear-steer linkage and don't hang down below the crossmember when using any of the common mengine mount adapter plates. S&P sells a cut/welded Fbody pan that also fits. This is all in the 1st gen swap FAQ (see the important threads sticky).
Old Oct 15, 2008 | 08:54 AM
Steve68's Avatar
A simple larger rock or brick at highway speeds will take out that pan, happened to a local member in FL, a rock truck, one carrying ornimental rock dropped all kinds on the road toasted the motor, pick a new pan or modify a F body,
Old Oct 15, 2008 | 09:01 AM
fast's Avatar
hey 69LT1Bird would you mind posting some pics of your modded pan?
Old Oct 15, 2008 | 12:41 PM
68rustbucket's Avatar
I'm still using the truck intake manifold, so if i raise it much higher I'll never get the hood to close.
Old Oct 15, 2008 | 02:44 PM
TAP04's Avatar
you can never be too low, if it doesnt scrape your too high!!!! hahahaha
Old Oct 15, 2008 | 03:01 PM
loweredd's Avatar
While that's true for the vehicle, it is not for the oil pan.
