fuel pressure reg
Old Oct 20, 2008 | 11:26 PM
markarleta1's Avatar
Default fuel pressure reg
im going to use a walbro pump does any one have any suggestions on regulators and filters that i should use? thanks
Old Oct 20, 2008 | 11:31 PM
cherryelky305's Avatar
pick up a corvette filter/regulator. it gives the right pressure for a stock like application. you didnt mention what your application is. is the motor going to be mostly stock or is it built up?
Old Oct 20, 2008 | 11:47 PM
its 5.3/4l60. can i just pick one up at the dealer? what do i ask for? thanks
Old Oct 20, 2008 | 11:58 PM
bczee's Avatar
The 99+ Corvette Fuel Pressure Regulator is a AC/Delco GF822.. you can pick on up at most parts stores (Autozone, Kragen's, Pep Boys, most Chevy Dealers). You can have it cross reference to other manufactors numbers.
Old Oct 21, 2008 | 12:23 AM
i just seen a picture of the ac delco gf822 can you explain the plumbing to me? thanks
Old Oct 21, 2008 | 09:36 AM
bczee's Avatar
It is a filter with a internal regulator. the side with the single port is the output to the fuel rail. the other side with the two port is the inlet and return. the return is the smaller tube.
Most will put it close to the fuel tank and that way, only one feel line is needed to the front and the feel from the tank and return lines will be short.
There are many threads/post on the filter as a subject, research on the forum. FYI, I am using one and it has worked great. You can either use OEM type connector (from a repair kit), use aftermarket quick disconnect adatper or just use fuel injection rated rubber hose and connectors (for the cheap route). Just remember that the pump feeding the regulator may exceed the standard 58-60 psi of the output of the filter, so the connectors or clamps need to be secure.
Old Oct 21, 2008 | 05:28 PM
i am using a 5.3 with a return on the rail do i still need to plumb that to the tank since the corvette fpr has a return?
Old Oct 21, 2008 | 05:45 PM
I thought you might have that problem, that might take some research to figure out, but off the top of my head i would just get an aftermarket regulator and plumb that in the return line off the rail, then put filters where appropriate. in any case good luck.
i know there are a few threads talking about the truck's fuel rail's though.
