starter
Try wedging a screwdriver across the two big lugs on the back of the starter. If it works then you are probably not getting enough volts to the start terminal on the starter. Most people call this heat soak and fix it by using a remote solenoid. It is caused by a weak solenoid and the voltage drop through the key start wiring.
What I would do is first make sure your battery terminals have been recently cleaned. Then you can take the solenoid apart and clean the contacts on the copper disk that shorts the two big lugs together from the inside. Lube up all the moving parts on the starter so everything engages smoothly.
You can try jumpering a wire straight from the battery to the S terminal to see if that makes a difference. If it does, trace the start wire back from the solenoid and clean with emery paper every electrical connection you see. If it still doesn't work, then do the remote solenoid.
http://carshop.carshopinc.com/produc.../95047/oess210
Use this diagram.
http://novaresource.org/starter.htm
