cma and crank sensor output voltages....
Old Oct 22, 2008 | 04:28 PM
1BadDime's Avatar
Default cma and crank sensor output voltages....
Can anyone tell me what I should be looking for as far as output voltages on the cam and crank sensors??
I turned the engine over by hand and checked for cam voltage, and it flips between 0v - 12v
while cranking the engine with the starter I checked the voltage on the crank sensor and I was getting about 3v or so while cranking. is this right?
both sensors have 12v to their power wires with ignition on, and both sensors are grounded properly.
I would like to know what to look for and how to look for voltages at their respective signal wires.
Thanks,
Jim
Old Oct 23, 2008 | 11:49 AM
RE AND CHERYL's Avatar
You will not get a steady output from these sensors as they are a megnetic hall efect sensor. Generally they are very reliable witha low failure rate. What is your reason for wanting to check them.
Re'
Old Oct 23, 2008 | 02:43 PM
1BadDime's Avatar
to make sure they are operating correctly. and operating within spec.
Jim
Old Oct 23, 2008 | 08:55 PM
Start the engine= operational check good
Old Oct 23, 2008 | 09:10 PM
1BadDime's Avatar
Well... I guess I could have explained in much more detail. but I'm troubleshooting as to why my engine does not start. Its ok, I got some good answers today from an MSD tech, and were tracking the problem down slowly but surely...we hope. haha
Jim
