Adapter plate dimensions?
Old Nov 3, 2008 | 10:03 AM
346_chevelle's Avatar
Default Adapter plate dimensions?
Im looking for the dimensions and hole locations for any motor mount adapter plate that would work best for a 67 chevelle. I want to utilize the stock frame mounts and motor mounts if at all possible.
Old Nov 3, 2008 | 11:07 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
I sell em cheap
http://carshop.carshopinc.com/produc...457/C/S%202370
Old Nov 3, 2008 | 02:29 PM
bczee's Avatar
You can find them in the FAQ / Sticky's on top of the Conversion/Hybrid forum... there is a template for both the older BRP and S&P style plates. You can also modify them as you need or move the motor mounts location if needed.
I built my with just normal hand tools, grinder, cutting wheel and a drill and tap. I powder coated them they look as good as any other one.
http://matt.undiagnosed.org/ls1/imag...ount_plate.jpg
http://matt.undiagnosed.org/ls1/imag...t_plate_V2.jpg
I even built them with both style combinded so that I could try both style into one plate. I ended up using the BRP due to the AC compressor and cut off the S&P extention.
Old Nov 4, 2008 | 01:36 PM
Chevy-art's Avatar
I bought mine from carshopinc on ebay, and they work great.
