new info on fox swaps
Old Nov 4, 2008 | 01:01 PM
leonpiper69's Avatar
Default new info on fox swaps
i know i was pissed cuz my mustang cant have a blower motor for my heat, but i did find out some good stuf....
1 you do not NEED to spend 200 dollars on a steering shaft.
i was able to just cut mine and slide a 4 inch piece of 1.25 tubing over it and weld it up. new shaft = 75 cents.
2. you can use the stock mustang drive shaft without cutting it.
my driveshaft was abou 2 inches too long and so if you just cut back the yoke , you can use the stock shaft the way it is.
just thought i would share some good news.
Old Nov 4, 2008 | 01:53 PM
djsanchez2's Avatar
Good to hear thanks for the info
Old Nov 4, 2008 | 03:45 PM
Capown's Avatar
not doing this swap netime soon but free info and eazy tricks to get the job done are always a plus!! thanks
Old Nov 6, 2008 | 06:10 PM
nuckifuts's Avatar
Why cant you have a blower motor? My car has heat and AC.
I used a section of my tire iron for my steering shaft at first, once it was nearing completion i went to a aftermarket one because my welding is suspect at best
Old Nov 7, 2008 | 01:47 PM
[QUOTE=nuckifuts;10435234]Why cant you have a blower motor? My car has heat and AC.
i ranted about htis awhile back, i put my pcm in the kick panel so the blower housing wont fit back in now, eventually i will cut the housing up and fiberglass it back together to fit.
