Spectre Fuel Tanks
Old Nov 6, 2008 | 11:48 PM
Northern Goat's Avatar
Default Spectre Fuel Tanks
I called Spectre and was told that the pump in the FI fuel tanks is set @90psi. My engine builder says my LQ9 only requires 58 psi.
Why would Spectre make a tank with such an excess volume.
Can anyone help me figure this out?
Old Nov 6, 2008 | 11:59 PM
casey38boost's Avatar
Thats what a fuel pressure regulator is for. The fuel pump doesn't have a built in one, u add one on the fuel line. I don't know about 90psi maybe they are rated max flow. Most people are using the inline Vette fuel regulator.
Old Nov 7, 2008 | 12:17 AM
I am planning on running the inline vette regulator myself. I just thought a drop from 90 to 58 psi seemed excessive. But it seems from other posts here that people like the tanks.
Old Nov 7, 2008 | 07:30 AM
ryanvv355's Avatar
The pump in the SPI tanks is a Delco EP381, the same pump found in 96-99 5.7 and 7.4 GM trucks. The Vette pressure regulator will be fine for you application, as the trucks with the pump had similar regulators.
Old Nov 7, 2008 | 09:00 AM
1967 Yenko Clone's Avatar
Where in Ontario did you get your tank from?
Wes:
Old Nov 7, 2008 | 09:27 PM
pist0lpete's Avatar
I would recommend rockauto.com for unbeatable prices on the SPI tanks. Apparently you can search google for an addition 5% discount as well.
Old Nov 7, 2008 | 10:04 PM
olblue51's Avatar
^^^ That's how I got mine... $444.52 shipped!!!
