fuel line question...
Do you know if your factory lines were 1 piece or if they had rubber splices half way?
I ask as you could have someone push lock flare your line on either end and then just buy some push lock fuel lines at your local auto parts place.
It many not be a good idea to run Rubber hose completly from back to the front. Heat sources (exhaust), Suspesion and chassic movement may be harmful or not recommended to be near or close contact with and failure may occure.
A combonation of both Rubber, metal tube or Stainess Steel braided hose should be used in the correct condition and location of your install.
Good luck and keep us posted on what you do...
