Anyone have a pinout for 06 Chev Express Van w/4L80?
Looking for a harness pinout for 06 Chevy Express van with a 6.0 and 4L80E trans. Would be nice to see PCM and body connectors if anyone has it.
Thanks in advance.
Ryan
Thanks in advance.
Ryan
Powertrain Control Module Connector End Views
Powertrain Control Module (PCM) C1
Connector Part Information
OEM: 12191110
Service: 12167308
Description: 80-Way F Micro-Pack 100W Series Sealed (BU)
Terminal Part Information
Terminal/Tray: 12084913/5
Core/Insulation Crimp: W/W
Release Tool/Test Probe: 12122523/J-35616-6 (BN)
Powertrain Control Module (PCM) C1 Pin
Wire Color
Circuit No.
Function
1
BK/WH
1551
Ground
2
L-GN
1867
12-Volt Reference
3
PK/BK
1746
Fuel Injector 3 Control
4
L-GN/BK
1745
Fuel Injector 2 Control
5-6
Not Used
7
GY
2705
5-Volt Reference 1
8
GY
2701
5-Volt Reference 1 (w/o JL4)
9-10
Not Used
11
L-BU
1876
KS 2 Signal
12
YE
573
CKP Sensor Signal
13
OG/BK
463
Requested Torque Signal (JL4)
14
OG/BK
1061
UART Serial Data (JL4)
15
D-BU/WH
774
16
Not Used
17
D-BU
1225
Transmission Fluid Pressure Switch Signal B
18
OG
1226
Transmission Fluid Pressure Switch Signal C
19
PK
439
Ignition 1 Voltage
20
RD/WH
440
Battery Positive Voltage
21
PU
574
Low Reference
22
Not Used
23
TN
2759
Low Reference
24
BK/WH
1551
Ground
25
TN
1671
HO2S Low Signal - Bank 2 Sensor 2
26
TN
1667
HO2S Low Signal - Bank 2 Sensor 1
27
BK/WH
1551
Ground
28
TN/WH
1669
HO2S Low Signal - Bank 1 Sensor 2
29
TN
1664
HO2S Low Signal - Bank 1 Sensor 1
30-31
Not Used
32
TN/WH
771
Transmission Range Switch Signal A
33
PU
420
TCC Brake Switch/Cruise Control Release Signal
34
WH
776
Transmission Range Switch Signal P
35
Not Used
36
TN
1744
Fuel Injector 1 Control
37
YE/BK
846
Fuel Injector 6 Control
38
Not Used
39
YE/BK
625
Starter Enable Relay Control
40
BK/WH
1551
Ground
41-42
Not Used
43
OG/BK
877
Fuel Injector 7 Control
44
L-BU/BK
844
Fuel Injector 4 Control
45
Not Used
46
GY
2709
5-Volt Reference 2
47
Not Used
48
GY
597
5-Volt Reference 1
49-50
Not Used
51
D-BU
496
KS 1 Signal
52
Not Used
53
TN
2762
Low Reference
54
OG/BK
469
Low Reference
55-56
Not Used
57
RD/WH
440
58
D-GN
1049
Class 2 Serial Data
59
Not Used
60
TN
2752
Low Reference (w/o JL4)
61
PK/BK
632
Low Reference
62
Not Used
63
BK
2755
Low Reference
64
BK/WH
1551
Ground
65
PU
1670
HO2S High Signal - Bank 2 Sensor 2
66
PU
1666
HO2S High Signal - Bank 2 Sensor 1
67
BK/WH
1551
Ground
68
PU/WH
1668
HO2S High Signal - Bank 1 Sensor 2
69
PU/WH
1665
HO2S High Signal - Bank 1 Sensor 1
70
BN
1174
Oil Level Switch Signal
71
Not Used
72
YE
772
Transmission Range Switch Signal B
73
BN/WH
633
CMP Sensor Signal
74
YE
410
ECT Sensor Signal
75
PK
1020
Ignition 0 Voltage
76
TN/WH
845
Fuel Injector 5 Control
77
D-BU/WH
878
Fuel Injector 8 Control
78
Not Used
79
WH
687
3-2 Shift Solenoid Valve Control (5.3L)
80
TN
2761
Low Reference
Powertrain Control Module (PCM) C2
OEM: 12191110
Service: 12167308
Description: 80-Way F Micro-Pack 100W Series Sealed (GN)
Powertrain Control Module (PCM) C2 Pin
Wire Color
Circuit No.
Function
1
BK/WH
1551
Ground
2
BN
418
TCC PWM Solenoid Valve Control
3-4
Not Used
5
TN/BK
464
Delivered Torque Signal (JL4)
6
OG/BK
1228
PC Solenoid Valve High Control
7
Not Used
8
L-BU/WH
1229
PC Solenoid Valve Low Control
9
D-GN/WH
465
Fuel Pump Relay Control - Primary
10-12
Not Used
13
L-BU/BK
396
Cruise Control Engaged Signal (w/o JL4)
14
Not Used
15
OG
225
Generator Turn On Signal
16
Not Used
17
D-GN/WH
2523
A/C Request Signal (C60)
18-19
Not Used
20
PU
401
Signal Low - Front
21
YE
400
Signal High - Front
22
OG/BK
1230
AT ISS High Signal (4L80-E/4L85-E)
23
D-BU/WH
1231
AT ISS Low Signal (4L80-E/4L85-E)
24
D-BU
411
TP Sensor Signal (w/o JL4)
25
TN
472
IAT Sensor Signal
26
PU
2121
IC 1 Control
27
OG
2127
IC 7 Control
28
L-BU/WH
2126
IC 6 Control
29
D-GN/WH
2124
IC 4 Control
30
Not Used
31
YE
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
Not Used
34
D-GN/WH
428
EVAP Canister Purge Solenoid Valve Control
35-36
Not Used
37
D-GN
83
Cruise Control Inhibit Signal (w/o JL4 or Early Production JL4)
38
Not Used
39
OG
631
12-Volt Reference
40
BK/WH
1551
Ground
41
Not Used
42
TN/BK
422
TCC Solenoid Valve Control (5.3L)
43
D-GN/WH
459
A/C Compressor Clutch Relay Control (C60)
44
Not Used
45
WH
1310
EVAP Canister Vent Solenoid Valve Control
46
BN/WH
419
MIL Control
47
YE/BK
1223
2-3 Shift Solenoid Valve Control
48
L-GN
1222
1-2 Shift Solenoid Valve Control
49
YE/BK
1827
Vehicle Speed Signal
50
D-GN/WH
817
Vehicle Speed Signal (w/o JL4)
51
YE/BK
1227
TFT Sensor Signal
52
PU
5035
HO2S Heater Low Control - Bank 1 Sensor 2
53
YE
5036
HO2S Heater Low Control - Bank 2 Sensor 2
54
PU
1589
Fuel Level Sensor Signal
55
D-GN
603
A/C Low Pressure Switch Signal (C60)
56
Not Used
57
TN
470
Low Reference
58
TN/WH
331
Oil Pressure Sensor Signal
59
PU
806
Crank Voltage
60
BN
2129
Low Reference
61
BN/WH
2130
Low Reference
62
GY
773
Transmission Range Switch Signal C
63
PK
1224
Transmission Fluid Pressure Switch Signal A
64
D-GN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PU/WH
2128
IC 8 Control
67
OG/WH
2122
IC 2 Control
68
D-GN
2125
IC 5 Control
69
L-BU
2123
IC 3 Control
70-71
Not Used
72
L-BU
5038
HO2S Heater Low Control - Bank 1 Sensor 1
73
Not Used
74
PU/WH
5037
HO2S Heater Low Control - Bank 2 Sensor 1
75
GY
23
Generator Field Duty Cycle Signal
76
L-GN/WH
1749
IAC Coil B High Control (w/o JL4)
77
L-GN/BK
444
IAC Coil B Low Control (w/o JL4)
78
L-BU/BK
1748
IAC Coil A Low Control (w/o JL4)
79
L-BU/WH
1747
IAC Coil A High Control (w/o JL4)
80
Not Used
OEM: 12191110
Service: 12167308
Wire Color
Circuit No.
Function
1
BK/WH
1551
Ground
2
L-GN
1867
12-Volt Reference
3
PK/BK
1746
4
L-GN/BK
1745
5-6
Not Used
7
GY
2705
5-Volt Reference 1
8
GY
2701
9-10
Not Used
11
L-BU
1876
KS 2 Signal
12
YE
573
CKP Sensor Signal
13
OG/BK
463
14
OG/BK
1061
15
D-BU/WH
774
16
Not Used
17
D-BU
1225
18
OG
1226
19
PK
439
Ignition 1 Voltage
20
RD/WH
440
21
PU
574
Low Reference
22
Not Used
23
TN
2759
Low Reference
24
BK/WH
1551
Ground
25
TN
1671
26
TN
1667
27
BK/WH
1551
Ground
28
TN/WH
1669
29
TN
1664
30-31
Not Used
32
TN/WH
771
33
PU
420
34
WH
776
35
Not Used
36
TN
1744
37
YE/BK
846
38
Not Used
39
YE/BK
625
40
BK/WH
1551
Ground
41-42
Not Used
43
OG/BK
877
44
L-BU/BK
844
45
Not Used
46
GY
2709
5-Volt Reference 2
47
Not Used
48
GY
597
5-Volt Reference 1
49-50
Not Used
51
D-BU
496
KS 1 Signal
52
Not Used
53
TN
2762
Low Reference
54
OG/BK
469
Low Reference
55-56
Not Used
57
RD/WH
440
58
D-GN
1049
Class 2 Serial Data
59
Not Used
60
TN
2752
61
PK/BK
632
Low Reference
62
Not Used
63
BK
2755
Low Reference
64
BK/WH
1551
Ground
65
PU
1670
66
PU
1666
67
BK/WH
1551
Ground
68
PU/WH
1668
69
PU/WH
1665
70
BN
1174
71
Not Used
72
YE
772
73
BN/WH
633
CMP Sensor Signal
74
YE
410
ECT Sensor Signal
75
PK
1020
Ignition 0 Voltage
76
TN/WH
845
77
D-BU/WH
878
78
Not Used
79
WH
687
80
TN
2761
Low Reference
OEM: 12191110
Service: 12167308
Wire Color
Circuit No.
Function
1
BK/WH
1551
Ground
2
BN
418
3-4
Not Used
5
TN/BK
464
6
OG/BK
1228
7
Not Used
8
L-BU/WH
1229
9
D-GN/WH
465
10-12
Not Used
13
L-BU/BK
396
14
Not Used
15
OG
225
16
Not Used
17
D-GN/WH
2523
18-19
Not Used
20
PU
401
Signal Low - Front
21
YE
400
Signal High - Front
22
OG/BK
1230
23
D-BU/WH
1231
24
D-BU
411
25
TN
472
IAT Sensor Signal
26
PU
2121
IC 1 Control
27
OG
2127
IC 7 Control
28
L-BU/WH
2126
IC 6 Control
29
D-GN/WH
2124
IC 4 Control
30
Not Used
31
YE
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
Not Used
34
D-GN/WH
428
35-36
Not Used
37
D-GN
83
38
Not Used
39
OG
631
12-Volt Reference
40
BK/WH
1551
Ground
41
Not Used
42
TN/BK
422
43
D-GN/WH
459
44
Not Used
45
WH
1310
46
BN/WH
419
MIL Control
47
YE/BK
1223
48
L-GN
1222
49
YE/BK
1827
50
D-GN/WH
817
51
YE/BK
1227
TFT Sensor Signal
52
PU
5035
53
YE
5036
54
PU
1589
55
D-GN
603
56
Not Used
57
TN
470
Low Reference
58
TN/WH
331
59
PU
806
Crank Voltage
60
BN
2129
Low Reference
61
BN/WH
2130
Low Reference
62
GY
773
63
PK
1224
64
D-GN
890
65
Not Used
66
PU/WH
2128
IC 8 Control
67
OG/WH
2122
IC 2 Control
68
D-GN
2125
IC 5 Control
69
L-BU
2123
IC 3 Control
70-71
Not Used
72
L-BU
5038
73
Not Used
74
PU/WH
5037
75
GY
23
76
L-GN/WH
1749
77
L-GN/BK
444
78
L-BU/BK
1748
79
L-BU/WH
1747
80
Not Used
You wouldn't happen to have the pinout for the plug that connects to the bottom of the fuse box, would you? I need the engine harness to fuse box plug pinout if you or anyone else has it.
Thanks again.
Thanks again.
