Throttle by wire?
Old Sep 19, 2003 | 02:23 PM
whitt1's Avatar
Default Throttle by wire?
I usually post in the truck section,but I was hoping maybe you guys could help with my problem.I am installing a TCI stand alone computer on my supercharged 01 Tahoe to run a 4L80E transmission.The TCI TPS plugin has 3 wires and the truck has 6 wires,basicly 2 TPSs in 1.When I splice the TCI wires to the corresponding ABC wires on the wiring harness the throttlebody does not work and shows a reduced engine power warning on the dash,but the transmission shifts.When I unplug the spliced connection the throttlebody works but the transmission does'nt shift.I hope someone can help me figure an answer to my problem.Any help will be greatly appreciated.Thanks whitt1
Old Sep 22, 2003 | 09:13 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Throttle by wire?
The guys in the Diagnostics and Tuning forum could probably help you out with this one.
Old Sep 23, 2003 | 12:32 PM
LS1 ZR2's Avatar
I checked the pin out for a 2001 Tahoe, and according to it, you should hook the wires in as follows. If you want to connect them at the PCM, J1/46 (gray wire) is the 5V supply, it is in cavity "A" at the throttle body TPS switch. At J1/54 on the PCM, you will find the 5V return (black wire), at the TB it is in cavity "B". The reference (or signal) is located at J2/24, or cavity "C" at the TB. This wire is dark blue.
Do not remove any of these wires, just splice the TCI box circuits to them. I use one of these controllers on my 427ci LS1 / 4L80E powered S-10, and it works fine.
