Syclone LQ4/4L80E tc78 build
#161
i ordered $330 worth of stuff from summit yesterday. fans, fittings and other stuff.
worked on the driver header today. I got about 3 hours into this one now.
and my intercooler came in today.
#168
did the passenger header today.
i first started out by mocking up the collector and down pipe.
then i did the two harder primaries. 2 and 8
then i did the rest
i also mockup the crossover
then i did the rest
#174
#176
#177
checking a/c clearance
finished the collector
and made most of the downpipe, starts below the header and goes about halfway down the tranny. cant do anymore on it until i get the turbo in
#178
welded the headers, downpipe, and crossover today. there all ready for paint and wrap
cut the core support for the intercooler
will probably do the tranny coolers and wiring tomorrow. i also got some 918 valve spring that i will put in tomorrow. i have z06 springs but extremetoy hook me up with some for $20.
#179
painted and wrapped the crossover
mounted the intercooler
installed the radiator fans and put the radiator back in, its alittle tight in there
prime gears is out of prop shafts so i am having a local shop build me one. that will be ready on tuesday. I got my stock rear drive shaft shortened and put that in yesterday. I ran my lines for tranny coolers and turbo oil drain yesterday too.
list to do
-mount tranny coolers
-finish downpipe
-make crossover/header to turbo y pipe
-turbo oil feed
-abs delete lines
-paint/wrap headers
-put oil in everything
-hook up wiring harness
-intake tubing
list to do
-finish downpipe
-turbo oil feed
-abs delete lines
-paint/wrap headers
-intake tubing
#180
Wonder how tight that is going to be once the fenders are in place. Could be closer or further away. Those core supports dont sit right without the fenders. Have you checked it yet?
