1995 mustang 6.0 conversion need info
[/IMG]this is the car im working with. i have a 6.0 and a 4L60E transmission the motor is out of a silverado and i've been researching and doing my homework on the build but i have a few questions for anyone who may have already done this swap.
1.) does anyone sell a crossmember for the 4L60E tranny im using?
2.) will granitelli control arms work with an aje tubular swap k member?
3.) does aje make motormounts for this swap?
4.) will i need an ls1 car harness to do this swap or can someone who is good with wiring use my mustang car harness and just add the lsx computer?
5.) with a tube k member will i be able to use a stock lsx oil pan?
6.) the car has 4.10 gears in the rear with that auto tranny and some nitrous an L76 intake and l92 heads what is the best size cam and converter for this build?
7.) is there anything else i might be looking over with this that may help me in the long run besides headers and driveshaft does anyone know how well the shifter lines up with the console on the inside of the car will i hafta cut on it to make it come through the floor or should it work in the factory mustang shifter location.
Thanks alot for any help guys i'll keep posted on the progress of the car it should come out pretty nice and my goal is to get it done by this spring so if theres anything that may need to be ordered now to meet dead line (backorder parts) let me know. like i said thanks again for the help any is greatly appriciated.
A. Thacker
Alot of that stuff you will have to measure once installed. Im sure someone here though has done an AJE k member in an sn95 and used the f body pan im sure. I am not sure if you are referring to the 6.0 oil pan or the f body pan. The truck oil pan would hang alot lower using the aje k member.
http://www.giffinsperformance.com/ra...turbo-t26.html
youll have to sign up to view it. but its a 1999 mustang turbo 6.0 swap
4l60 tranny anymore a buddy of mine had a 350turbo tranny a tci 3500 converter and a quarterstick for 300 buck so i bought that to use instead and i found the headers i needed and k member & cross member so other than the wireing situation i should be good to go to get the motor in now its just savin the money for heads cam and intake and hopefully i'll have this pile on the road
