LS1 in a 93 corvette
Old Nov 13, 2008 | 12:46 PM
vetteman9368's Avatar
Default LS1 in a 93 corvette
So my 93 vette has been a garage ornament for the past few years. Going to put a carbed LS1 in it, figured there would be a few people here who have done it before me. This will be a strip only car, so it won't have any of the normal street equipment on it. Any insight would be appreciated
Old Nov 13, 2008 | 01:02 PM
the_merv's Avatar
Veteran: Air Force
Auto or T56?
Old Nov 13, 2008 | 01:15 PM
Originally Posted by the_merv
Auto or T56?
probably a TH350 or 400....I have a few laying around. Of course I also have a liberty pro-shifted T-10
Old Nov 13, 2008 | 01:17 PM
bczee's Avatar
Are you going to a solid rear end ? You may want research into that..... the Dana 36/44, depending on the HP level may not hold up to a strip / race only.
The swap it self should be no problem, many have done the C4 to Gen III/IV swap..
Old Nov 13, 2008 | 01:39 PM
I am using a Tom's differential 12 bolt center section from a C3, 300M outers, Chromoly halfshafts and Coil Overs. Got teh rear end covered, going to get started soon on the cage and crossmember
Old Nov 13, 2008 | 03:51 PM
bczee's Avatar
Ok.. keep us posted, I many some day do my 88' Coupe... Have you looked into any of the adapter or are you going to make your own ?
are you still going to utilize the C-Arm from trans to rear ?
Old Nov 13, 2008 | 06:12 PM
going to fab my own mounts. And I will be building a trans crossmember, as well as a torque arm from the center section to the trans crossmember
