Wiring a LS1 into a LT1 Car
#142
I know this is an old thread BUT....
"Fuel Pump Relay Ground:
This is a Black Wire that is on that C210 Connector on the Car. This Wire is in the Harness, and it has to be matched to this one. It sometimes is referred to as the Sender Ground. Put this Wire into the Male C210 Connector with the Starter Wire."
I get that this goes to C210 under the Kick Panel in the car, but where does it come from? Does it come from a PCM connector on the LS ECM or one of the passenger side Kick Panel Connecters from the LS1 Harness or from one of the Wheel Well Connecters from the LS1 Harness?
#145
A few questions with this, what PCM are you using, has VATS been deleted, and can you hear the starter relay clicking under the right side of the dash when you turn the key? Is the fuel pump priming?
#146
I need to get in here more often and check this post..
Tied in with the grounds in the Engine Harness if I remember right.
Scan for codes, check grounds... few things here.
Send me a text fool... been a min
The following users liked this post:
G Atsma (09-26-2023)
