Need help identifying Connector/Plug - Pix inside.
Old Nov 16, 2008 | 11:03 PM
bimerok's Avatar
Default Need help identifying Connector/Plug - Pix inside.
Hi all,
Can anyone help me determine what this connector on the picture is for? It is only one pin connector and I can't seem to find what's it for? It is on the engine from 2002 Pontiac Firebird (LS1)
Any help is appreciated!
Attached Thumbnails Need help identifying Connector/Plug - Pix inside.-dsc_0347.jpg   Need help identifying Connector/Plug - Pix inside.-dsc_0348.jpg
Old Nov 16, 2008 | 11:16 PM
pist0lpete's Avatar
Thats the wire for the starter. Depending on what you are swapping the engine into you may just wanna use the starting setup already in the vehicle. Or you can route the wires to that one.
Old Nov 16, 2008 | 11:50 PM
bczee's Avatar
+1 on the Starter wire.. GM usually use the heavy gage purple wire for that.
Old Nov 17, 2008 | 07:26 AM
bimerok's Avatar
This engine will go in to non-GM vehicle.
So is this an ignition switch signal or constant power to starter?
Thanks
Old Nov 17, 2008 | 09:40 AM
bczee's Avatar
It would be to the Ignition switch (start term).
Old Nov 17, 2008 | 09:55 AM
the_merv's Avatar
IGN Switch to the Starter. That Wire in the LS1 Cars goes over to the Fuse Box area for part of the VATS System.
Old Nov 17, 2008 | 10:10 PM
bimerok's Avatar
Thanks for the help guys. Just finished pinging some wires and it makes sence now.
