ls1 and lh8 oil pan into 69 Camaro -question
I just ran into the same problem with using the LH8 pan in my 69 camaro. I'm using Trans dapt engine plates and the mounts won't line up at all. After examining I realized the this damn LH8 pan was sitting on the subframe and was not allowing the engine mounts to line up.
This is an old post, but I am having the same problem with oil pan clearance to the front crossmember as Les SS. Is there something obvious I am missing. Less did you find a solution or get an answer? Thank you
