FPR w/quick disconnect
Old Nov 23, 2008 | 12:00 AM
BBPanel's Avatar
Veteran: Marine Corps
Default FPR w/quick disconnect
I understand the Vette FPR has a quick-disconnect fitting on it - how do these fittings work? - I guess they are secure given they run on them on production cars. Anyone have a close-up pic of one? And what does the end look like that goes into this fitting?
Since it doesn't look like there is enough material on the fitting to cut it off and use an AN fitting as an alternative couldn't one tee off downstream of any regulator and accomplish the same thing as the Vette FPR and eliminate the qd fitting?
Old Nov 23, 2008 | 01:14 AM
the_merv's Avatar
They work by clipping on to the part that is like a lip.
Which side are you trying to make work? I had a custom Line made with Male Ends to connect to the Female Fitting on the Filter/Regulator..then I used the stock LT1 Connects to go into the other side of it.
Old Nov 23, 2008 | 12:20 PM
BBPanel's Avatar
I'm trying to understand how these fittings work before buying one I guess. I'm just concerned about a high pressure fitting that is not threaded and positive. Are all three fittings the same (qd) - just that the inlet side is female?
I thought about using compression to AN fittings for the discharge and return lines and I think a conversion is made for the inlet side - does someone make a conversion from the qd to AN for all three lines because I am not going to run rubber hose - that way if/when the filter/reg goes bad it would be much easier to replace.
Old Nov 23, 2008 | 12:39 PM
BBPanel's Avatar
Is this what I'm looking for for the male side of the fpr?
Old Nov 23, 2008 | 12:53 PM
bczee's Avatar
For the two ports (male) for the Inlet and Return, yes you can use these types of QD's.. I use the Russell ones. 1 = 3/8" (Feed) and 1 = 5/16" (Return).
As far as the outlet side (to the fuel Rail/engine), many have just used a old peice of tubing that has the correct barb on it and then either used a compression fitting or flared it and used AN Adapters. If you can not find a peice, you can use the Domain (part number is in the FAQ, Stu Cool posted the part number) part that is about 12" long with a barb on both end.
Old Nov 23, 2008 | 01:52 PM
BBPanel's Avatar
Yes that is the Russell fitting - so do these fittings just push together and seal somehow - how do they release?
Old Nov 23, 2008 | 04:36 PM
bczee's Avatar
To release then, go to the nears parts store and pickup a setup GM Fuel and Trans line release tools.
The tool is used to insert around in into the fitting on the opening side and then pushed in to release the tabs which allows the tube to be pulled out of the fitting. It is not hard to use.
