ls2 throttle body?
Old Nov 28, 2008 | 07:55 PM
strtlegal's Avatar
Default ls2 throttle body?
Having to switch from a fly by wire to a cable style throttle body. Trying to figure out which throttle cable i could use and where to hook it up, as well as a decent priced throttle body.
I noticed lokar makes one for the ls1, but the ls2 does not have the mounting tabs on the side to makes there system work. just curious what has been done out there..
Thanks
Old Nov 29, 2008 | 05:01 AM
the_merv's Avatar
Veteran: Air Force
You might have to have a Custom Throttle Cable made. As far as a Throttle Cable Bracket, I'm making one for mine cause the L76 Intake doesn't have one either.
You could buy a Holley 90mm Throttle Body, I have seen them come with Throttle Brackets.
Old Nov 29, 2008 | 07:37 PM
strtlegal's Avatar
i did not know that thanks!
