L92 engine swap ?s
First option that I've heard is to take out the old 5.7 and harness, put the new engine in with the harness and hook it all up, using a preferrably 05+ under hood fusebox for the two largest connectors of the harness. While leaving all of the other wiring in the truck from the 96
Second option is to pay for custom harness from Speartech etc. and then be able to do whatever I want. I plan on modding the engine some (cam, headers, intake, exhaust valves, possible blower if lucky enough) so that factors into the equation as well. Do I have to have all of these mods completed to get the most out of the harness, or can they change the computer settings as I mod it (and will this cost more money to have the settings changed) Also how much do most custom harnesses cost as I have heard wide variation.
Thanks a lot for your help...know that it is much appreciated
This is a Gen III but should be basically the same. Plus what trans are you running?
Thanks for the help
I watched the video on the chevy truck they transplanted it looked very sweet
As for the AWD you will really like it. I am on my 3rd Denali truck with the AWD and it is great. The only down side is that when you do want to do a big smokey burnout you can't. With my 01 C3 (Denali) I had an ATI procharger on it and even while turning in the rain and flooring it the truck would still get traction and accelerate hard.
As for the L76 car intake you will have to change the water pump and the front drive accessories. This poses a problem when keeping the VVT because you have to run the truck crank pulley to clear the front cover on the engine due to the VVT stuff inside. Mast has a spacer set to properly offset the F-Body front accessories on the motor to work with the truck crank pulley.
I think since you are going into a Tahoe I would keep the truck intake and the truck accessories as it will fit and would be much less headaches. They have a cam setup for the truck intake as well that makes 530hp.
