LS3 swap harness?
Old Dec 4, 2008 | 12:52 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default LS3 swap harness?
Who have you guys had good experiences with respect to buying and using LS3 swap harnesses?
Old Dec 4, 2008 | 03:38 PM
Jones'n's Avatar
We just did one not too long ago from Current Performance, they are who we have used for a lot of stuff and they are close by which is nice.
I would imagine that Speartech would be another good option.
Old Dec 4, 2008 | 10:20 PM
jw33's Avatar
I had good luck with the GM harness kit for my LS2. I think they make one for the LS3? I got mine from www.sdparts.com
Old Dec 5, 2008 | 01:02 AM
Project GatTagO's Avatar
If you are going with a stock LS3 and a manual trans, the GMPP harness is a good option.
Andrew
Old Dec 5, 2008 | 10:00 AM
LS1Tech Co-Founder
No manual trans Andrew.
Old Dec 5, 2008 | 10:09 AM
If you need transmission control you can go with a Speartech auto harness. Another option is to use the GMPP harness for the engine and get a programmable transmission controller and use this:
http://www.twistmachine.com
Andrew
Old Dec 5, 2008 | 10:45 AM
Chris442's Avatar
Needs to finish car
I had great luck with my Speartech harness for the LS7. I thought the price was actually very good for what I got. It may be a bit pricier than other solutions, but you can customize to what you want. The quality is definitely there. I also can't say enough about John's knowledge of how these things work.
Are you going to use a 6L80E?
Old Dec 5, 2008 | 11:10 AM
MastMotorsports's Avatar
We're doing them with our M-90 controller. Available with Wide Band capability or without. Available with 6L90E transmission capability or without. Two wire interface to a TCI or PCS transmission controller for 4L60E/4L80E control. Also available with two camshaft upgrade options.(535HP or 550HP) All packages come calibrated and ready to run.
With these packages, you can essentially create one of these engine packages.
Mast Motorsports LS3, LS3HO, & LS3SS
Hope this helps!!!
Old Dec 6, 2008 | 10:22 AM
LS1Tech Co-Founder
Not sure on the trans yet but it will be auto. I thought I had read the 6L80's need extra pedal work or something?
Old Dec 6, 2008 | 12:36 PM
Chris442's Avatar
Needs to finish car
I honestly have no idea what they take to get working, but I can tell you the 6L80E in my Mom's G8 is fantastic. It's got all the gear spread of a T56 car, and with some programming to quicken the shifts it really comes alive. It's a lot smaller and more efficient than a 4L80E, but it's still very strong. The downside is it's still very heavy.
