2002 Camaro vacuum lines ?
Old Dec 5, 2008 | 06:55 AM
Lance-W's Avatar
Default 2002 Camaro vacuum lines ?
I'm putting this engine in a 69 Camaro. What do the vacuum lines in the picture do? What is the part in the second picture that the vacuum lines are hooked to? I've already had the harness modified and the connector that is shown attached to the part in the second picture has been removed from the harness. Do I just plug the vacuum lines shown in the first picture?
Thanks, Lance
Old Dec 5, 2008 | 07:07 AM
oange ss's Avatar
A = is used for A.I.R. system control
B = is used for interior HVAC control
C = A.I.R. system control valve
Old Dec 5, 2008 | 07:14 AM
Lance-W's Avatar
So I can just plug the lines and call it done?
Old Dec 5, 2008 | 09:12 AM
rockytopper's Avatar
Yes
This link might help I had the same basic questions when I started my 2002 swap.
https://ls1tech.com/forums/conversio...eng-mount.html
Good luck with your build
