Miata wiring harness for LS1 conversion??
Thanks in advance. I'm sure I will have more questions along the way
Its mainly just providing power to the right pins of the pcm at the right time and your golden, if you can read pinouts and wire an ignition switch.. your 90% of the way there.
If this is your first swap goodluck. If I had known what I know now I could have done my swap in 2.5 weeks instead of 2.5 years.
Keith, who responded above works for a Miata specific shop that uses the v8roadsters kit to do Miata conversions so his answers are from direct experience.
I'm about %75 done my conversion and am working on the wiring right now.
Frank
the wiring for this swap is VERY straight forward. i would recomend getting a factory mazda wiring diagram from the original shop manual as well as a gm wiring diagram from the EXACT donor car. one year off, and you might as well be using a ford diagram! i opened up the mazda harness and removed all of the wires from the mazda ecu to the mazda engine. this made the mazda harness into a body harness just like a gm. then you simply connect the powers and grounds from the gm engine harness into the mazda fuse box. you can use the gauge sending units from the mazda on the chevy engine to allow the mazda gauges to work correctly. if you get stuck you can contact me. my swap has been running for almost 4 years now. good luck.
karl
