2000 lq4 flexplate/spacer ?'s
I picked up a 2000 LQ4 (iron heads) that was originally mated to a 4l80
Is this one of the engines that came with the crank flywheel spacer/diff flywheel?
Also, This would mate to a t350/t400 without any issues? and if I wanted to run a 4l60e I'd need to remove the spacer and get the other flywheel??
It should have the solid long crank flange on it and isn't removable see the picture! The later ones 01 and up, or so, had a removable spacer for use on the LQ9 etc. That will rule out a later Gen III 4l60.
![](http://www.babcox.com/editorial/ar/elements/040538f.gif)
That definitely answers the question.
Mine is about 3/8" to 1/2" out from the rear
I still have to change the pan and windage tray so I could have just looked at the casting# if all else failed
Actually it is removed for use with the 4L60E trans. The LQ4 and LQ9 were both used with the 4L60E and 4L80E. The 4L80E required the extra length to mate up to the flexplate to the converter (SBC style).
But you might have to elongate the holes in the flex plate. And make sure you have the flat 6.0L flexplate.
Will a 2000 LQ4 bolt up to a T400? From what I read above it will. But the converter bolts are a different diameter than the original converter(?).
Does anyone know of a SFI flex plate for the longer crank? What is the manuf and P/N?
