LQ4 in a 1971 Nova
-Recam
-Keep everything else the same: I have 10.5:1 CR with Mahle forged rods/pistons and a stock crankshaft
I've run over the accessory changes in the Forced Induction section (link above), but I'll repost here.
If you're just sticking to stock boost, there are 6-rib drives for truck spacing from both LSX Concepts and ICT Billet, but I'm going to overdrive the supercharger so I elected to use the 8-rib for the supercharger and Corvette spacing for the rest of the accessories.
Accessory Drive BOM:
--LSA balancer
--LSA/C6 water pump
--ICT Billet alt/PS bracket for Corvette spacing
--Any LS alternator EXCEPT CTS-v
----Older Type II pumps will need to be modified, see below
--OPTIONAL: High-mount AC bracket (ICT and LSXConcepts both make one, I was able to reuse my own design)
--C6 belt tensioner (Dayco PN 89616 for referenece)
----Attached to the AC bracket, otherwise it would attach to the water pump
----The 75mm ribbed pulley off of the tensioner is used as an idler on the AC bracket
----Smooth pulley for the tensioner
--Belt TBD
The ICT Billet bracket was inexpensive enough to warrant its purchase over designing my own. It was designed for a C5 Corvette power steering pump, but that is essentially identical to the older Type II
Accessories installed. The idler and tensioner are close but won't touch during normal operation
AC bracket spacer calculations
AC bracket design with idler and tensioner
Alternator and PS pump installed (no PS pump pulley). I will redo the steam line.
*EDIT* As a point of reference, my NA build with 10.25:1 CR and 4.030 bore has 0.019 and 0.021 top and second ring gaps respectively as recommended by my local builder. As another example, this guy running an LSA with 4.070 bore with a dished piston (doesn't say CR) targeting 16psi boost was told by Wiseco to use a 0.028 and 0.030 top & second ring gaps. I understand not gapping rings enough for boost can quickly lead to failure.
The cam will have a larger LSA to minimize boost bleed-off. I’m leaning on a CamMotion PD cam.
Bad news... the Type II pump and pulley I have don't align with the Corvette spacing. I should’ve seen that coming. Welp. I’ve ordered a C5 aluminum pump, pulley and universal reservoir. I will also need new fittings.
Now that I've finished the accessory drive, I can focus on the supercharger and heat exchange system. Items left to purchase (though I'm sure that I'm missing something):
I've installed the Corvette pump. I was able to get it fired up with a temporary reservoir and all seemed fine, but I need to figure out a permanent solution. The Corvette reservoir looks like it will interfere with the LSA inlet and throttle body, but I'll likely need to create a bracket for the CTSv reservoir.
ICT Billet bracket showing Corvette reservoir.
LSA showing PS reservoir for reference.
LSA PS reservoir
I finally got it buttoned-up and did a shakedown run (aka dropping kids off at school followed by commute). I might actually have to relocate the reservoir again when I install the supercharger, but I'll figure it out when I get there. I did have to bend the front steam tube, but I understand that this is needed for the LSA anyway.
The red wire from the alternator is for the "S" pin, which senses voltage at the main power distribution. I added this after the fact and it solved my low alternator voltage issues. The unused holes at the top of the bracket are for Corvette alternators.
So I'm still mulling what to do with the SC drive. My high-mount AC means I can't use the OEM setup. LSXConcepts.com make a simple drive, but it's $350 for a belt, tensioner ($150 on ebay) and piece of milled aluminum and isn't recommended for overdrive pulleys. I'd like to figure something else out.
I've also been looking at heat exchangers. The LSA uses air-to-water, so I don't have to shove a giant HX in front of the radiator like our air-to-air comrades. I've found that AFCO's ZL1 replacement, PN 80283, is a popular choice. It's 26x11x3". I need to check whether it would work, especially with my AC condenser. I've also considered finding a HX to stick toward the back of the car, with its own dedicated fans. I could then stick a big reservoir tank in the trunk, and use the fuel pump turn-on signal for coolant pump and fan relays since the Vaporworx ZL1 pump module is back there. Ideas?
The only issue is the hot Phoenix summer. However, I measured my shroud and found that if I were to move the fan as far to one side as possible, it would clear up enough space to fit 2 small (8” dia) fans on either side. It’s not much, but I could tie those two into my high-speed wiring. Spal makes 7.5” diameter fans that flow just over 400 cfm, which would theoretically provide an additional 800cfm of cooling airflow (obviously less in practice).
I took some more measurements and pulled the trigger on the Afco ZL1 unit, PN, 80283NDP, which is 26" x 11" with dual 1" rows. It's a dual-pass unit with both inlet and outlet on the driver's side. I'll dive into the front when I receive it.
I'm still working out the supercharger drive system. I bought an OEM tensioner and plan to add an idler on the slack side near the supercharger pulley. I won't be able to really dig in until I get the supercharger on the car and double-check that my measurements and maths are correct.
I purchased an OEM LSA tensioner, but the provision for a breaker bar to relieve tension is opposite the pulley rather than integrated into the arm, and it hit the hood. Luckily Gates and Dayco have pretty good online catalogs and I was able to find something that should work. I'm waiting on that so I can finalize my AC/tensioner bracket and figure out belt sizes. I'll also need to put together a PCV system. Any of you boosted fellows want to point me in the right direction? Oh and the hood hits the supercharger (I closed it off with fiberglass last summer), and the grill will need to be trimmed to fit the heat exchanger (turns out it's 3" not 2.5" like I thought!).
The last major hurdle is tuning the car. I don't have HP Tuners, so I'm asking if anyone has the MPVI hardware that I could borrow or rent to get my feet wet. PM me please. I realize I need to download the VCM suite and buy credits, which isn't an issue. I'm merely looking for the hardware for a short period, maybe a week or two. And if I get the hang of it I'll ship it back and buy my own.
