Throttle cable
Old Dec 17, 2008 | 08:09 PM
dhdenney's Avatar
Default Throttle cable
Apparently basic questions are unwelcome in other parts of the forum... I need to know which throttle cable I am going to use for my 1994 LS1 conversion. It will be a non trac control version however I do not know what year throttle body I've got. Running Vic Jr. with ultra low profile elbow.
Old Dec 17, 2008 | 09:48 PM
Rodder's Avatar
Lokar TC-1000LS1
Old Dec 17, 2008 | 10:04 PM
the_merv's Avatar
Will the NON TCS LS1 Throttle Cable work? That is what I'm going to be switching the one I currently have to.
Old Dec 18, 2008 | 07:20 PM
dhdenney's Avatar
I checked it out on Summit and I'm not sure if it's a generic pic or what but it does fit the stock TB?
Old Dec 20, 2008 | 11:04 AM
Rodder's Avatar
Lokar TC-1000LS1 fits the stock LS1 throttle body.
Old Dec 20, 2008 | 12:32 PM
dhdenney's Avatar
Excellent. Does it have a little bit of adjustment cuz I'm not sure how the Vic Jr and elbow are gonna sit in relation to where stock would be.
Old Dec 20, 2008 | 01:11 PM
Rodder's Avatar
The Lokar cable is cut-to-fit. You cut the housing to the length you need, then run the inner cable through the housing, bolt on (set screw) the knub that hooks in to the throttle arm, and then clip off the excess cable. You can easily adapt it to any bracket setup as long as the bracket is at least 2 inches or so behind the throttle body.
Old Dec 20, 2008 | 03:15 PM
dhdenney's Avatar
Excellent that's the info I needed!
